Mio Moov M410- I have found method how to enter Upgrade screen, but how to unbrick???
I have one bricked Moov M410.
It has overwrite AppStartupSec.exe with Systeminformation menu...BUT...
menu has wrong entered addresses for launch igo8
Of course USB don't work.
So i have disassembly this mio for searching how to access to upgrade screen and i have found it.
1) Turn MIO ON (disassembled)
2) Connect USB cable between Mio & PC.
3) Unsolder red battery + from mainboard (stay connected with USB)
4) Short on board + red and - black battery pins ... mio turns off and led diode blink orange/green
5)Press reset switch for approx 2 seconds
6)Press and hold ON/Off for approx 10 seconds
Now is mio on blue screen with text
"Please send the Image through USB"
But what can i do now ? I have installed drivers for SEC SOC SMDK board and then run DNW.exe. On dnw is USB:OK, but i cannot flash any firmware - i have tried moov M400 fw.
Can You please help me?
29th October 2012, 06:22
#2
Re: Mio Moov M410- I have found method how to enter Upgrade screen, but how to unbric
Hallo! Method doesn't work.
1) Turn MIO ON (disassembled) - OK
2) Connect USB cable between Mio & PC. - OK
3) Unsolder red battery + from mainboard (stay connected with USB) -OK
4) Short on board + red and - black battery pins ... mio turns off and led diode blink orange/green -OK
5)Press reset switch for approx 2 seconds - OK
6)Press and hold ON/Off for approx 10 seconds Mio doesn't switch on.
What's wrong? Please help!
