Have had the same problem with MIO MOOVE 200
ZIPPYSHARE
RAPIDSHARE
INSTRUCTION
1. Format SD card to FAT and copy Cobia_300_32 to root folder on SD card
2. Open sat nav , take out mainboard and remove metal parts which cover chipsets
3. Inside you should see TSOP 48 NAND FLASH. Connect permanently pin no.19 (write
protect) with pin no. 12 (VCC) .Next I make short-circuit pin. 9 with GND in different
moments when I turn on sat nav (SD Card inside).
4. After few moments sat nav was reading files from SD card. You should get 2 options :
USERMODE and SUPERMODE. Choose first one, click OK then restart your MIO.
5. You should see blue service screen.
It was working for me on MIO MOOVE 200. I have tried many times with success.
