Thread: Mio c520, miomap icon doesn´t works
    Question Mio c520, miomap icon doesn´t works
    I had a Mio C520 unlocked and all worked great. However one day after connect the GPS to the pc with an usb cable, the gps stop to work. I can switch on and click on every icon less the "miomap" icon. So I can´t access to the GPS unlock. I try with the sd card inside and without sdcard, all is the same, I can´t access to miomap icon and I can´t launch the unlock.
    Two questions:
    1.- Does anybody know who to fix this issue?
    2.- Is there any possibility of install the unlock to run directly instead of click on the miomap icon to work?
    Thanks a lot!
  2. The Following User Says Thank You to drakeramoride For This Useful Post:
    Re: Mio c520, miomap icon doesn´t works
    First i think You must tell to the people what unlock did you use?
