Thread: mio moov v505 help update.
    oynak is offline Sergeant Major
    Belgium, Brussels.
    169
    102
    hi guys.
    I've unlock my mio moov S505.
    I may use other nav soft.
    But :
    1°) I can't use the TV mode.
    2°) I want to update the original soft inside. I've europe till austria.
    I want maps for croatia, slovenia, serbia, bulgaria, greece, fyrom, Turkey and hungary.
    3°) the original tmc works with miomap but not with igo8 or primo.
    The tmc is undetectable.
    Thanks for your helps.
    3,134
    216
    Re: mio moov v505 help update.
    Quote Originally Posted by oynak View Post
    hi guys.
    But :
    Edit your device original software thru device settings or task manager.
    Set them on top of all applications.
    If using Miodesktop - edit path thru MP settings.
    TMC on com 1.
    Paths will not work out without edition to it.
    Make sure you have a full backup of the original software
    It will brick someday so be prepared.
