Results 1 to 9 of 9
Thread: How do I get the GPS programs match the Icons in MIO
    I have a MIO Model N179 and I have unlocked it using Mio unlock. I have IGO 8 program but there is no short cut icon for this. If I put the programs, Amigo, Navigon, Tom Tom etc on the GPS will those icons light up. How is this achieved and can I substitute a icon for IGO8. Can any one help. Thanks, Nikkitty.
    3,134
    216
    Re: How do I get the GPS programs match the Icons in MIO
    Which unlock program did you installed.
    Your post too brief to understand.
    Thanks for the quick reply Airion. The unlock was Moi Unlock/Shell Visual shell by Dalibor Lanik . I have managed to get iGO 8 installed with the icon on the Info page not onto the Nav page. I add that this is on the flash memory not onto a SD card.
    3,134
    216
    You can try tapping and hold on the icon.
    See whether a small window opens.
    See properties and edit path for new icon on nav page
    For icon change - explorer / unlock / settings
    find icon folder - check and replaced icon but make sure you edit the icon size to the same.
    Use image editor or any photo editor to change the png icon sizing
    Thank you for that, its working well.
    dalanik's Avatar
    dalanik is offline Second Lieutenant
    257
    No need to edit any icons or files. If you are using any of the supported GPS programs, they already have icons. All you have to do is go to the SYSTEM screen:
    ...and select icon for setting paths to programs. It is icon with folder. You will see list of all programs. just press corresponding button to set it's path:
    Visual Unlock Mio * Visual Unlock Becker * If you like my work, DONATE
    __________________________________________________ ________________
    iGo8 * Amigo * Primo * Destinator * MioMap * PolNav * NDrive * Navigon * R66
    Mireo * Sygic * Gamba * MobileNav 9 * Spirit * AutoMapa * Garmin * TomTom
    3,134
    216
    Thanks Dalanik
    I have N179 also. How to instal visual. What to change and where fo this model. Thanks
    dalanik's Avatar
    257
    Quote Originally Posted by eug_60 View Post
    www.lanik.org
