Page 2 of 61 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 609
Like Tree4Likes
Thread: Visual - Mio Moov GPS unlock/shell
  1. #11
    Rick is offline Lance Corporal
    The Nederlands
    Re: Visual - Mio Moov GPS unlock/shell
    dalanik:
    I have a good feeling about the Unlock/Shell, I have it installed on the flash disk now and it is running fine, except for the USB connection and resume from sleep.
    I tried running it from a fast SDHC Card, because of little free space on flash disk, but I got stuck after the GPS init, the visualshell.exe win not start.
    The resume from sleep I solved by adding a Sleep(7000) after
    If(ProcExists("VisualShell.exe"))
    Exit
    EndIf
    in the auto.mscr.
    But the USB connection works ownly after a SoftReset, the USB button does not work on my Mio moov 500.
    Any suggestion?
    Rick
  2. #12
    dalanik's Avatar
    dalanik is offline Command Sergeant Major
    245
    What exactly is happening when you put device to sleep and turn it back on?
  3. #13
    The Nederlands
    dalanik
    I removed the 7 seconds delay, but I can not reproduce the error messages right now.
    If I see them again I post them here.
    And want about the USB connection button that does not work?
    Can you let me anything about it?
    Rick
  4. #14
    dalanik's Avatar
    245
    Rick:
    Sorry, I have no idea - this works on most moovs but all mio's are different. I can't do anything about it unless you find out what is needed since I don't have your device.
  5. #15
    The Nederlands
    dalanik
    I read the instructions again and tried clicking USB first and then connecting the cable.
    That resulted in the following error:
    Fatal Application error
    Application MortScript.exe has
    performed an illegal operation
    and will be shut down. if the
    program persists, contact the
    program vendor.
    Program: MortScript.exe
    Exception: 0xC000005
    Address: 0005827C
    With on the background the screen "Wait..." "Terminating original apps..." and
    then no responce after clicking "ok" on the fatal error.
    I wil try to debug the script connect_usb to see where the error comes from.
    I figured out why I put in the sleep(7000) in the auto.mscr.
    On a Boot with USB cable connected I got the following error:
    An empty BigMessage box
    and on top Message with:
    Error
    Couldn't write file \My Flash Disk\Visual\Script\launch.ini
    Line 110 (\Storage card\Visual.ins\Unlock.mscr):
    WriteFile(ScriptFolder\"launch.ini", ScriptFolder\init.mscr")
    after this no responce from the Mio but USB connection is active!
    When I put in the sleep(7000) then there is no error and on remove of USB Cable the Mio reboots automatically.
    If I interput this right my SDHC card is online and running the scripts before the flash disk is online!
    Sound strange he?
    One other tink: The Mio moov 500 does not seem to have an internal clock!
    Miomap 2008 does a time sync with GPS but TomTom nor Unlock/Shell does this.
    Something for the next version? Or is it something simple I can add?
    Rick
  6. #16
    dalanik's Avatar
    245
    Are you using SD-card method? Try putting everything to the flash disk. This is the only stable setup. The SD card route is just if you want to try it out but it is best to have everything on Flash disk.
    All mio gpses are missing internal clock. this is simply fact. it gets time only when it gets fix. but it should remember it if you don't RESET it - and there is no need to reset, i.e. my moov in standby mode can run for several weeks before the battery empties. So there is no solution. It simply must get fix in order to get time.
  7. #17
    Hellrayser is offline Sergeant
    42
    Quote Originally Posted by dalanik View Post
    All mio gpses are missing internal clock. this is simply fact..
    I dont think so,when you say something be sure 100%
    http://www.youtube.com/watch?v=So3Ad__xAYU
    movie 2 moore clear
    http://www.megaupload.com/?d=WN3QWL90 No Pass:
    P.S for your fear .....Flash Format
    http://www.youtube.com/watch?v=5h7fvkM75Mg
  8. #18
    dalanik's Avatar
    245
    Well if it looses clock after reset it is more than obvious it doesn't have internal clock. But I don't want to get into debate with you, .............
  9. #19
    Nenaptio is offline Private
    what os and stuff were those games made for? bcause those are the games my gps can run, but all the other versions of the games i cant run...
  10. #20
    42
    Well if it looses clock after reset it is more than obvious it doesn't have internal clock. But I don't want to get into debate with you,...........................
    First I must tell you I have not offended,but
