Page 3 of 61 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 609
Like Tree4Likes
Thread: Visual - Mio Moov GPS unlock/shell
  1. #21
    Rick is offline Lance Corporal
    The Nederlands
    Re: Visual - Mio Moov GPS unlock/shell
    Quote Originally Posted by dalanik View Post
    Are you using SD-card method?.
    Yes I am!
    Try putting everything to the flash disk.
    No, not enough free space.
    The SD card route is just if you want to try it out...
    I am trying it out and it is not bug free.
    All mio gpses are missing internal clock. this is simply fact.
    I am just poiting it out for you, because you do not have a mio moov 500.
    it gets time only when it gets fix. but it should remember it if you don't RESET it
    That is just it, when I put it in sleep mode for a day, time is remembered (but it does not advance) it runs a day behind!
    So far there is nothing you had an answer for I am just trying to help out by testing on an other device type.
    I do not think you appreciate it? Or do you?
    Rick
  2. #22
    dalanik's Avatar
    dalanik is offline Command Sergeant Major
    245
    Hellrayser:
    Do what you want, I don't care. I am not here to prove anything. I just made something for myself and thought I might want to share with other people. You are the one who has a complex of inferiority since you always post how you are better and smarter. Even in your unlock thread you state "best" unlock. Do what you want, I just want you ot of the way. From now on I will IGNORE all your posts.
    Nenaptio:
    They are made for Win CE. What other games?
    Rick:
    I dunno, I can only test on my moov, and it runs just fine, no bugs. I just want to point out that if yu want something solved, you can't expect me to solve it because I din't have a means to test it. You must solve it and I can include the "fix" in my last build. I hope you understand that it's very hard to fix something if you don't have that device I didn't check if my moov remembers the time - I think yes -- but this shows you that it's totaly unimportant to me, or how I use GPS. When I get a fix, time synchronizes and that is enough for me. I can try to make it better but again - hard without the device.
    D.
  3. #23
    gpsu Guest
    Hi Hellrayser,
    This is a community for support and sharing.
    Please be gentle in your words and people are ready to help.
    GPSU
  4. #24
    Sumiko40 is offline Private
    I need some help, please..
    I got a C220, Digiwalker, and I just can't find any instructions on how to make it work.. I have downloaded the files from this topic, and copied them into an SD-card 100% correctly.
    But the navigator doesnt load up ANYTHING from the SD-Card..
    I haven't changed anything at all on the navigator, and I also havent edited anything on the downloaded files from here...
    They are in my SD-Card now, please help me, to find out how I can make the navigator load from the SD-Card...
    Thanks in advance.
  5. #25
    oynak is offline Sergeant First Class
    114
    35
    hello guys.
    I've a mio moov 330.
    I downloaded the soft on a SD card but nothing happens when I put it on my device.
    Did I have to do something?
    thanks.
  6. #26
    Nenaptio is offline Private
    Hellrayser:
    Nenaptio:
    Rick:
    D.
    there are some other games made for ppcs, i meant games like those... some of the windows ce games ive installed in the past also seemed to not work... like where are the sites to get windows ce 5.0 apps/games?
    btw, i have a magellan roadmate 1470 using miopocket
  7. #27
    dalanik's Avatar
    245
    Sumiko40, oynak:
    Please read the instructions on my site. You have link to instructions in the 1st post.
  8. #28
    114
    35
    Thanks I 'll try again.
  9. #29
    Sumiko40, oynak:
    I have seriously tried EVERYTHING.. Look, I have just restored the Mio C220 to it's standard Software, so it's like it's 100% new now. I got 60 MB free on it. On the SD-Card, I still got all the 3 folder in it, places like the instruction say.. Now, I don't care if I shall use the memory on the Mio (Flash), as I can always restore it with the standard software.. But only thing the instruction say, when it's a Digiwalker, is "Copy files from folder MioC520 to the root of your SD card (not the folder itself, only files!!)".. I have tried this over and over, and nothing happen.. The GPS doesn't load ANYTHING from the SD-Card... Please help me, step-by-step, to make it worth through the Flash, like the instruction said.. What files shall I copy? I got 3 folders you know, Visual, Visual.auto, and Visual.ins.... What files shall I copy, and where shall I copy them to?
    Thanks.
  10. #30
    dalanik's Avatar
    245
    As far as I remember (and I installed it only once looong time ago to C520 as far as C-series devices are concened):
    You must use SC card method.
    * copy folder VISUAL to flash disk
    * copy folder VISUAL.INS to STORAGE CARD
    * copy contents of MioC520 to the root of your card
    * turn on device, let it boot normally without SD card
    * insert SD card
    let me know if it works. As I say, in some version of visual long time ago when I implemented this, it worked and people reported it works. But I can't check and nobody complained. If it doesn't work, maybe some other C-series owner can help.
    D.
