Page 59 of 61 FirstFirst ... 9495758596061 LastLast
Results 581 to 590 of 609
Like Tree4Likes
Thread: Visual - Mio Moov GPS unlock/shell
  1. #581
    ciprian73 is offline Corporal
    Nov 2012
    18
    Re: Visual - Mio Moov GPS unlock/shell
    @gyany
    Thanks a lot,but this version of Garmin don't run.
  2. #582
    orion.gre11 is offline Corporal
    Dec 2011
    22
    Hi I have install Visual gps on a mio spirit 480.On the first page of the unlock shell appears the igo8 and igo primo.Where I must write the igo primo and under what name to run the program??????
  3. #583
    John Dough is offline Sergeant
    56
    Quote Originally Posted by orion.gre11 View Post
    Did you load to the drive or sd card.
  4. #584
    Dec 2011
    22
    To drive, Idont have sd card.
  5. #585
    56
    Create a new folder say "gps progs" on your drive and put your programs in there visual will pick them up and open.
  6. #586
    Feb 2013
    Hello all,
    one small question. Does Visual GPS works with resolution 480x272?!
    I will soon have Mio Moov 671 Spirit and I wan't to try Visual GPS on it...
    Did anybody tried to use this on model?!
  7. #587
    Dec 2011
    22
    Quote Originally Posted by nenad76 View Post
    Hello all,
    Yes I have try the visual to spirit 480 with your resolution.
  8. #588
    Feb 2013
  9. #589
    Feb 2013
    hi to all,
    i have mio cruiser 5165...can this visual unlock my device? am not sure if my device is moov, spirit or navman.
    if it can, i wanna use the 3rd option (completely from flash)
    my proccessmgr shows below...
    can you please check which appcall to edit from the below?
    apcall00 = \My Flash Disk\Program Files\MioBT\MioBT.exe,-h HFP PHBOOK,0,1,1,2000,
    apcall01 = \My Flash Disk\Program Files\MainShell\MainShell.exe,,0,2,2,2000,
    apcall02 = \My Flash Disk\Program Files\AV_IN\AVINMgr.exe,,0,0,0,2000
    scrsavconf = 31,2000,,,
    or is there anyother way around?
  10. #590
    56
    You should see the following in your flash disk: myflashdisk\Programfiles\Miomap or system or miomap\appstartupsec.ini if they are not there then you cannot use it as these are all the mio ones..
    "apcall00 = \My Flash Disk\Program Files\MioBT\MioBT.exe,-h HFP PHBOOK,0,1,1,2000,
    scrsavconf = 31,2000,,, "
    Above lines should NOT be altered or you will brick your device
