Page 61 of 64 FirstFirst ... 11515960616263 ... LastLast
Results 601 to 610 of 640
Like Tree8Likes
Thread: Visual - Mio Moov GPS unlock/shell
  1. #601
    dalanik's Avatar
    dalanik is offline Second Lieutenant
    257
    Re: Visual - Mio Moov GPS unlock/shell
    Quote Originally Posted by ikac View Post
    Figured out, please ignore.
    Glad you got it working.
    Visual Unlock Mio * Visual Unlock Becker * If you like my work, DONATE
    __________________________________________________ ________________
    iGo8 * Amigo * Primo * Destinator * MioMap * PolNav * NDrive * Navigon * R66
    Mireo * Sygic * Gamba * MobileNav 9 * Spirit * AutoMapa * Garmin * TomTom
  2. #602
    IvecoDaily is offline Sergeant
    Jan 2011
    54
    It doesnt work for my C510 DigiWalker...
    i Copy Visual.auto and Visual.ins and content of Mio c520..(mort scripts) to the root of my sd...and it doesnt want to run at all...what am I doin wrong? I tried that to put SD after starts etc...but nothing
  3. #603
    Jan 2011
    54
  4. #604
    dalanik's Avatar
    257
    Quote Originally Posted by IvecoDaily View Post
    Did you copy ALL files from the C520 folder to the root of the SD card?
  5. #605
    Apr 2013
    São Paulo, Brazil
    I´m a happy VisualGPS user since last year. Thanks a lot from this amazing work. My brazilian Mio S505 has a new lif now!
    But I´m facing a little cosmetic problem. I have downloaded and custom iGo Primo package, and a another package user has designed an .ICO file for the package.
    The file has the .ICO extension. And Windows Explorer says it´s a 100x100 icon file, just as other regular .ICO files, provided by VisualGPS.
    I copied this file to the \Visual\Skin\Icons folder (stored on my Mio S505 internal flash memory, as the other parts of the VisualGPS package) and has pointed to it, editing the Visual.ini, as follows:
    [Primo]
    PATH=\Storage Card\Infinity\Infinity.exe
    PATH2=\Storage Card\Primo\Primo.exe
    PATH3=\Storage Card\Enterprise\Enterprise.exe
    ICON3=\Storage Card\Visual\Skin\Icons\Primo-Enterprise.ico
    All navigator are stored on external microSD flash card.
    But the Primo menu doesn´t show the third icon... :-(
    So, my question: has the .ICO VisualGPS file a special format? I noticed, indeed, that all .ICO provided has the same 40,6Kb, while my custom Primo-Enterprise.ico is big as 149Kb!
    Thanks for any help!
    Best regards,
    Luis Santos
  6. #606
    Apr 2013
    São Paulo, Brazil
    [Primo]
    Best regards,
    Luis Santos
  7. #607
    dalanik's Avatar
    257
    Quote Originally Posted by lcdsantos View Post
    Yes, those are real icons. First of all, you need ALL icons in an icon pack (or folder). You also need icons.ini file which you can edit, i.e.:
    [Main]
    name=Icons.Back_in_Black
    author=Dalibor Lanik
    url=http://projects.lanik.org
    Then, and most important, icons must be 100x100 pixels in size. I think that is all...
    cheers,
    D.
  8. #608
    what comport did you use for igo? in sys txtcom baud nimea?
  9. #609
    dalanik's Avatar
    257
    Port should be 2, speed 57600.
    Sent from my GT-N7100 using Tapatalk 2
  10. #610
    Sep 2012
    Hi dalanik.
    I am running the latest version of Visual (v115.01) on a Mio C320 Digiwalker and am having a very similar problem to that in post #597.
    For me it's a new install, rather than an upgrade, but much of the rest is similar.
    Visual itself is installed using "method A" and boots up fime when I insert the SD card. However, although I have selected iGO8 and Primo as my alternative GPS navigators, the icons for iGO8 and Primo insist that the programs are not installed. (Like in post #597, I am able to run the programs by double-clicking on them, so they are there and working.)
    A look at the visual.ini file shows that the paths of the two alternative programs were correctly written to the file, so the failure to recognise the programs is puzzling.
    FYI, I ntried switching the pages off and on as you recommended, but it had no effect.
  1. 22nd March 2012, 15:36
  2. 20th March 2012, 12:44
  3. 17th March 2012, 21:13
  4. 6th March 2012, 10:43
  5. 25th February 2012, 18:44
  6. 22nd February 2012, 18:11
  7. 11th January 2012, 14:09
  8. 23rd November 2011, 10:25
  9. 18th November 2011, 08:10
  10. 29th September 2011, 21:52
  11. 20th July 2011, 22:39
  12. 4th July 2011, 04:39
  13. 24th June 2011, 07:56
  14. 22nd June 2011, 10:16
  15. 25th May 2011, 22:33
  16. 4th May 2011, 19:33
  17. 10th April 2011, 08:21
  18. 4th April 2011, 17:04
  19. 18th March 2011, 00:18
  20. 13th March 2011, 14:31
  21. 6th March 2011, 00:18
  22. 4th March 2011, 22:06
  23. 27th January 2011, 21:35
