Page 1 of 61 1231151 ... LastLast
Results 1 to 10 of 609
Like Tree4Likes
Thread: Visual - Mio Moov GPS unlock/shell
    dalanik's Avatar
    dalanik is offline Command Sergeant Major
    245
    Visual - Mio Moov GPS unlock/shell v115.01
    Requirements: Mio Moov, Mio Spirit, Mio Cxxx device - with 480x272 resolution (or 320x240 resolution for unofficial version)
    Overview: Unlock your Moov and use shell to easily lounch applications on your moov
    UPDATED 2011/11/28
    Features:
    * Unlocks Mio Moov, Spirit and Cxxx devices
    * Shell with big, easy to use during driving buttons
    * Boots in seconds
    * Only essential applications:
    - media players
    - picture viewers
    - pdf, word, excel, flash, ebook viewers
    - games
    * Tweak settings of MioMap 2008/Spirit
    * Change look in seconds! Highly customizable
    You can read all about it here:
    http://visualgps.lanik.org/
    http://projects.lanik.org/GPSProject_00CZ.htm
    http://projects.lanik.org/GPSProject_00SR.htm
    Download Instructions: Full download. Just unrar and copy to device flash and sd card (installation instructions included in readme file). Freeware.
    https://rapidshare.com/files/6947770...PS_v115.01.rar
    pw: visual
    mirror:
    http://www.megaupload.com/?d=J5NUIY4G
    pw: visual
    Version for 320x240 devices by xrimar:
    http://rapidshare.com/files/333263224/Visual320_240.rar
    pw: visual320
    mirror:
    http://www.megaupload.com/?d=O14JUM56
    pw: visual320
    The games that are not included in archive can be downloaded here:
    Rapidshare
    pw: games
    mirror:
    MegaUpload
    pw: games
    installation instructions:
    just copy whole folder PDAmill to \My Flash Disk\Visual\Programs\Games
    The cracked GPS Skinner (not included in the archive) can be downloaded here:
    http://rapidshare.com/files/297009205/GPS_Skinner.rar
    pw: skinner
    mirror:
    http://www.megaupload.com/?d=ZUAD03F0
    pw: skinner
    installation instructions: just copy to exe to \My Flash Disk\Visual\Programs\GPS Skinner folder, overwriting the trial exe
    Wallpapers:
    http://rapidshare.com/files/40414952...paper.rar.html
    no password
    mirror:
    http://www.megaupload.com/?d=N9W9N18R
    no password
    This version should work with CE6 devices
    oxili likes this.
    PipiMajster is offline Private
    Re: Visual - Mio Moov GPS unlock/shell
    Can I try and unlock my Becker Z102 with this tread?
    dalanik's Avatar
    245
    Probably the shell part would work if the resuloution is 480x272 but the unlock part would have to be modified. If you have time, you can try playing with unlock.mscr in visual.ins and Auto.mscr in visual.auto folders.
    Hi dalanik will this work with an old navman n60i device with win 5.0?
    thanks
    AHMHeeren is offline Sergeant
    The Netherlands
    47
    Hey Dalibor,
    good to read you are back on this forum.
    I'm looking for an unlock for my mio moov 500 which I can run fully from my SD Card. I tried yours but as you mentionede, everything works except it doesn't launch MioMap 2008. Has there been another bright guy who has solved this ? In other simple unlocks I read the instructions to change the miomap.exe in a miomap folder within the programs folder. Om my mio moov there is however no miomap folder to find: there is a navman folder and the program seems to be started with the SmartST_CE.exe file in there.
    May be the bug in the SD unlock version is due to a scripting that is based on finding a miomap.exe file instead of looking for the SmartST_CE.exe file ?
    I'm not an expert here, but hopefully this might help those who are to get the bug out ?
    THX/Ton
    dalanik's Avatar
    245
    AHMHeeren:
    Did you se tthe path to Navman's SmartCE (or what it's called) in Visual setup? Just set it as MioMap and as Default programs.
    The Netherlands
    47
    Dalibor,
    I guess I was not clear enough with my question here.
    My question is not about Visual, I tried the simple unlock that runs completely of the SD Card from your website which works except it doesn't launch MioMap 2008. You mention this bug on your website, I just wonder if there is a solution for it allready.
    dalanik's Avatar
    245
    AHMHeeren:
    Sorry I don't use that unlock - I might have tried it at one point, try contacting author of that unlock.
    D.
    Rick is offline Lance Corporal
    The Nederlands
    AHMHeeren:
    I managed to get MioMap 2008 working on my Mio moov 500 with the unlock/Shell by changing "Default" on the System page "Set paths to GPS programs" to "My Flash Disk\Program Files\Navman\SmartST_CE\Smart_CE.exe".
    But I am running the unlock/Shell from "My Flash Disk" not from "SD".
    I tried to run it from SD by modifying all "My Flash Disk\Visual" to "Storage Card\Visual" the hole initialization works but halt after completing the GPS init.
    VisualShell.exe does not start.
    What did you do to get it running from "SD" ?
    Rick
    dalanik's Avatar
    245
    Rick: The unlocks are much more stable when running from Flash than from SD. That is why I made it so it must run from Flash. Also nav programs - I strongly suggest that you put all your nav programs on flash and maps on SD.
