Results 1 to 10 of 17
Thread: BEST unlock Shell for Mio Moov All Range 4,3 and 4,7"
    Hellrayser is offline Sergeant
    42
    Thumbs up Blue unlock Shell for Mio Moov All Range 4,3 and 4,7"
    Only Mio Moov 480_272 & 480_232 Range
    Created especially for Moov range, we take account of all dependencies in Windows device
    to remove all errors that could occur.
    Unlock is simple, without too many options (to save RAM), but based navigation, easy to install and user friendly enough.
    Requirements: Mio moov all series 480_272 and 480_232 rezolution Windows CE 5.0 and 6.0
    Overview: Unlock your Mio Moov
    Features :
    1. No AppStarTupSec.exe needed
    2. No MioMap needed
    3. Bright and volume adjustable
    4. Screen Align
    5. Video
    6. Acces to my flash disk and Storage card
    7. PictureViwever
    8. Task Manager
    9. Hard reset Button
    10. 3D Push Button
    11. 8 Navigation Button
    12. shell can be edited and customized
    13 MioMap.exe or SmartST_CE.exe and AppStarTupSec.exe is no longer needed to adjust bright and volume
    East european shell (mioMap.exe)
    http://www.megaupload.com/?d=AXKX1YMO
    Path to navi software:
    \My Flash Disk\Program Files\MioMap\MioMap.exe
    \My Flash Disk\Program Files\Magellan\Magellan.exe
    \Storage Card\Sygic\Sygic.exe
    \My Flash Disk\Program Files\Ndrive\Ndrive.exe
    \My Flash Disk\Program Files\Amigo\amigo.exe
    \My Flash Disk\Program Files\Mireo\Cardinale.exe
    \Storage Card\Navigon\Navigon.exe
    \Storage Card\Navigation\TomTom.exe
    West Europe Shell (SmartST_CE.exe)
    http://www.megaupload.com/?d=Q3EFFH00
    Path To:
    \My Flash Disk\Program Files\Navman\SmartST_CE\SmartST_CE.exe
    How to:
    1. Connect device to PC
    2.Make a recovery of all flash
    3.After recovery delete all flash
    Atention : do not disconet device from PC
    4.Unrar content directly to your flash,after copying all the job is done
    5. copy back your navigation software (optional)
    6. unplug usb cable from device
    IMPORTANT
    Magellan Folder and Magellan.exe is to have acces to all navigation Button do not deleted
    For User witch use MioMap.exe and SmartST_CE.exe please delete from folder AppStarTupSec.exe and AppStarTupSec.ini
    God Bless Romania
  2. The Following 6 Users Say Thank You to Hellrayser For This Useful Post:
    Re: BEST unlock Shell for Mio Moov All Range 4,3 and 4,7"
    Nice skin. Lightweight and simple, and wasn't that hard to customize. Good Work!
    I customized it a little differently than you might expect, however. I have an image with all my buttons already drawn (used as the background image), and don't need animation effects. So I set the button image name to a blank 1x1 transparent png file (but stretched to the same shape as your original design), and removed the labels (my image already has them). Since I only run one program for GPS services, I also removed the nav submenu and reordered buttons somewhat.
    How would you suggest others customize the shell? Or, maybe it would help to explain how the XML files relate to the menu operation for others.
    PS - Saw the other thread where someone was arguing about whether it was safe to wipe the Mio Flash via USB and drop your files onto it, but I did it, and it works well for me. I still have to run an SD card for other programs and data, but it's nice to see all the free space on the internal flash, if I ever need it (~900M).
    Thanks again, and I love having back-light control again!
    42
    I'm glad you like,someday I'll make a tutorial
    P.S a moderator please delete all of this post attachments and rename my " BEST unlock Shell for Mio Moov All Range 4,3 and 4,7" "
    to " Blue unlock Shell for Mio Moov All Range 4,3 and 4,7" " I do not want to feel offended dalanik
    Re: BLUE unlock Shell for Mio Moov All Range 4,3 and 4,7 (just skin or code updates?)
    Is this just an update to the images (skinning) or are there any code updates? If it's just a skin change, I'll hold off, but if there are bugs being fixed, I'll update the executables on my PNA.
    Thanks again...
    42
    Quote Originally Posted by joeisuzu View Post
    Thanks again...
    No bug fixed because my unlock run perfecly,is just an skin update
    oynak is offline Sergeant Major
    Belgium, Brussels.
    169
    102
    @Hellrayser,
    Did I have to erase everuthing inside my device??
    I've all this list of apps & folders.
    42
    in your case you must erase ( or cut and past into PC) just AppStarTupSec.exe and AppStarTupsec.ini than copy unlock and paste directly to your flash rewrite if necessary (you must unrar unlock first to be copied)
    also cut and paste into PC from flash;
    App_startup
    Autorun=virus also known like Autorun.inf
    paths
    Belgium, Brussels.
    169
    102
    Hi hellrayser.
    I think that I made a bulshit.
    I' erase everything.
    Not a problem I'll recopye everything.
    If I'v good understand, I should Erase only Appstarupsec.exe & ini.
    I'v to copy all the other downloaded files into my device.
    Is that?
  10. #9
    42
    Quote Originally Posted by oynak View Post
    Hi hellrayser.
    Is that?
    only if you want to keep it,my unlock works without your flash program,off course you need dbvtv ,etc,etc
  11. #10
    Belgium, Brussels.
    169
    102
    on the pictures that I put, I can only see app-startup.
    I didn't seeAppstarupsec.exe é ini.
    is it normal?
