Results 1 to 10 of 20
Thread: Need help: Original Flash disk file - Mio Moov 500 - America
    Hai Nguyen is offline Lance Corporal
    Hi all.
    I am from Viet Nam and also buy from ebay US a GPS Mio Moov 500.
    Unlucky, It does not come with CD or DVD software so I have deleted some folder before backup.
    Can any one have this file, pls help
    High appreciate your support
    3,134
    216
    Re: Need help: Original Flash disk file - Mio Moov 500 - America
    what is your version Cobra 500
    R 8.0.1 xxxxxx or R 8.0.2xxxx
    Check with Mio here
    You must have problems with miopocket.
    Hanging at desktop or fail to boot properly.
    Thanks much Airion, I also contact Mio and hope they can help.
    Btw, my moov 500 :
    Mode No: N210
    S/N: BEG88Mxxx9
    Rom: 500R2NA V1.9540.0012
    at the moment, flash disk was format and it can connect to PC like USB disk
    3,134
    216
    If in this case you can just install any unlock program
    and use it as it is.
    Basically - moov system is just an operational file system,
    work like any os.
    You just need a mio directory with exe to start the unlock program
    Yes, I also want to unlock and using Navman Unlock method : Any one can send me the mio folder: Navman - program files directory and also files in root directory, tks so much
    3,134
    216
    Quote Originally Posted by Hai Nguyen View Post
    Just make a directory Navman
    Rename the Navman unlock exe file as Navman.exe
    That will start the unlock program.
    Just wait for the installation to complete.
    Advice - put the Navman Directory in flash disk.
    Try out the unlock program in the sd card.
    Make sure it is suitable for your device.
    Miopocket is not stable for Moov device - my experiences
    Thanks Airion, I have follow your suggest and now Moov 500 can startup and run the Navman unlock soft but I really dont know why:
    1. Ozi.. : Can receive GPS signal (com 2, 57600)
    2. Papago X5SE: running but no GPS signal
    3. Mapking Landmark: running but no GPS signal
    Both Mapking and X5SE using Com 2, 57600 file.
    (I used to run Mapking, Papago succesffuly, same SD card, same file)
    Pls help
    3,134
    216
    If the two program can start. No reason for being unable to receive GPS signal.
    Better check the unlock internal configuration text for software.
    They must be missing as the unlock was not created for asian software.
    Maybe you need to add them in.
    Sure, I also think that some file or configuration is missing.
    The unlock I used may base on the original software, while OZi is completed install from Setup file. Papago or Mapking just copy and run only.
    Anyone have SmartST_CE.MSCR, pls help to send me quanghai.nguyen@gmail.com
    3,134
    216
    There is only smartst_ce/data/devicefeatureset xml file only
