Thread: Problem with mio moov 200
    basith9381 is offline Private
    Helloo,
    I have edited 'PATHS.XML' in my mio moov 200, now can't access to flsh drive using pc. it stucks on the orange screen
    does anybody know any solution to restore it to old state?
    100
    Re: Problem with mio moov 200
    try hard reseting few times (from reset to off) while the device is conected to the computer
    miomoshe,
    thank you for your reply,
    I tried it already, but it didn't help. also I tried to connect a wire form flash memory's 9th pin to GND, no success ,.
    any other solution miomoshe?
    sucro's Avatar
    sucro is offline Staff Sergeant
    91
    21
    Try to find mio desktop applicaion, or something like that, i forgot name of mio oficially application for their devices, look at mio web site, or somewhere on net... With that application try with option "REINSTALL SOFTWARE" or somethin like this, that option will reinstall your mio software and put device in facotry settings...
    Another option, try to discharge battery fully, and to power on device with battery like that, sometimes that helps... But first try with reinstalling mio software with mio desktop app...
    Good luck
    Greetzz
