Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: "No valid unlock id" problem
  1. #21
    3,132
    223
    re: "No valid unlock id" problem
    Quote Originally Posted by marcus02 View Post
    err i dont understand about this ....
    Use ultraedit to open the gmsup file and change the references.
  2. #22
    adieputra is offline Private
    Finally it work, thank for the solution... but then i got this problem.. when i rerun it for the 2nd time it crash and this massage appeared
    "write access violation at data address 0x00E9A000. program address 0x40063C24 in background thread NULL (GfxFieldWindowProc)"
    anybody can help, please....
  3. #23
    3,132
    223
    Quote Originally Posted by adieputra View Post
    Which ID did you use to create the unl.swl
    Device or sdcard
    What version of Xt did you install.
    Your PDA model
  4. #24
    Reconquista - Santa Fe - AREGNTINA
    Camilo823, espectacular lo tuyo ya que ,trabajé mucho para poder llegar a esto y nunca pude ,ahora anda un balazo !!
    Adios a los desbloqueos invalidos a los winCe 6.0.
    Gracias por el post, te pongo un 11.-
    saludos
    Salvador Cuocina
    Proyección Electroluz S.R.L.
    Dpto Aviación
    (54)9 3482-591403
    aviador_satr@hotmail.com
    piloto.agricola@gmail.com
    Skype User: aviador_satr
  5. #25
    Device or sdcard
    Your PDA model
    Actually i used the original unl.sw file that is given by bro camilo823. i cannot used other because of the "No valid Unlock ID" problem.
    my gmxt version is 5.00.20wp and china made PND with winCE6.
  6. #26
    3,132
    223
    Go to settings/about and see the device and sdcard id.
    Use only this sdcard id to generate a unl.swl
    Don't just copy and use. It is invalid.
  7. #27
    tried already, but my device will go to the previous problem cannot detect the gps device and the "No valid Unlock ID" come back..
    my device can only accept that given unl.sw file. i also thy to generate a new unl.sw using the "ID" but still no luck..
  8. #28
    kenta2 is offline Private
    try and change from unl.sw to sw.unl and I think it should work
  9. #29
    No, es indistinto que el sw.unl sea en minúscula o mayúscula.
    Salvador Cuocina
    Dpto Aviación
    (54)9 3482-591403
  10. #30
    Device or sdcard
    Your PDA model
    Problem solve already... thanks for the helping
