Results 1 to 10 of 10
Thread: Firmware v1.0707.0409
    MatrixPlasm is offline Lance Corporal
    Here's the latest FW for the 21XXmax ... anyone else have some others to contribute?
    - http://www.mediafire.com/MatrixPlasm
  2. The Following 8 Users Say Thank You to MatrixPlasm For This Useful Post:
    pluto30306 is offline Corporal
    29
    Re: Firmware v1.0707.0409
    Can you check your link again..the file seems to be missing.
    Could anybody be kind enough to tell me how to use this?
    Stockholm, Sweden
    Quote Originally Posted by MatrixPlasm View Post
    Thanks a LOT!
    It was the ONLY package my flashmemory-erased 2110 max could read from the sdcard!
    Sanco/Sweden
    I copied the files to the root of the memory card. I reset the navigon but nothing happened. What am I doing wrong? How do I upgrade firmware?
  7. The Following User Says Thank You to ctab For This Useful Post:
  8. #6
    Stockholm, Sweden
    It's not enough with only reset...You have to do a "factory reset" put the sd-card with the package above installed...reset in the bottom....directly after a reset hold power-button for a couple of seconds while the PDA is connected to external power.
    Than You can see the 5 secs countdown for Factory settings...
    Wait a couple of minute for the update sequence (starts automaticly)
    If it's not working try to format the sd-card to FAT32!
    Good luck!
  9. The Following User Says Thank You to sanco For This Useful Post:
  10. #7
    Jul 2012
    can this work in navigon 20 easy ?
  11. #8
    pmaiden5 is offline Captain
    685
    148
    Can anyone re upload this please ??
    Thanks in advance
  12. #9
    seal777 is offline Corporal
    Romania
    20
    93
    Talking Re: Firmware v1.0707.0409
    Quote Originally Posted by pmaiden5 View Post
    Thanks in advance
    Hello, hope is not too late ,here is firmware of navigon 2100 max.
    A few instructions turn off your unit,insert sd card with this files (extracted),turn on your gps unit,and then wait ,until is done.Enjoy!
    PS: sorry for my english hope you understanding!
  13. #10
    Mar 2013
    Hi, I have a 2100 (no max), can I use this update? if not, where can I find it, the firmware and the maps.
