Results 1 to 10 of 20
Thread: Need help, 2100max, formatted SD but no software backup
    Ice
    Ice is offline Private
    I have tried every download i have found, and no matter what, it passes the device ID screen and freezes on the Navigon screen
    I could really use some help getting this working again, im getting a larger SD card to fit the newer software/maps and i have a 3-year map update (haha fat lot of good thats done me, with only 2 updates in the 6months ive had the damn thing)
    anyways, could anyone tell me what settings i should check or perhaps send me a zip files or upload their software for me? really need this working for work/craigslist/life
  2. The Following User Says Thank You to Ice For This Useful Post:
    pluto30306 is offline Corporal
    29
    Re: Need help, 2100max, formatted SD but no software backup
    Quote Originally Posted by Ice View Post
    Try this updated file for the 5100 MAX, which is the same hardware.....http://www.mediafire.com/file/z2zonz...5100%20Max.rar this file is the SD version of the 4310 MAX.
  4. The Following User Says Thank You to pluto30306 For This Useful Post:
  5. #3
    Ice
    i already downloaded and tried your file, i got the same problem, im not sure where the problem lies
    with your software on my device, it wont load, and when i try to update or download maps using fresh, it says invalid device definition
  6. The Following User Says Thank You to Ice For This Useful Post:
  7. #4
    29
    I found the original 2100Max software. Load this software to get things working and then we can determine what is going on with your device. Since you have a Fresh Maps subscription, use the orginal software to connect and then let the natural process of upgrading everything via Fresh Maps.
    The version I found didn't have the autorun files in the main sub directory..so I added the ones I had for the 2150. IF it doen't boot, don't worry, your Fresh Maps update will update the software.
    http://www.mediafire.com/file/vhmwdy...l 2100 Max.rar
  8. The Following User Says Thank You to pluto30306 For This Useful Post:
  9. #5
    Ice
    i got an authentication error unzipping using winrar, i will still give it a go and see if it works, fingers crossed, may be a few days, having wisdom teeth out today
  10. The Following User Says Thank You to Ice For This Useful Post:
  11. #6
    Ice
    grrr, ya i wouldnt put too much stock in fresh, fresh just hates me or something, it recognizes the SD card as the location for the MN software, but it still gets an invalid device definition
    could be it missed a file due to the authentication error durring unzipping? i dont know :-(\
    Edit: hold on, i put the software on the wrong SD, give me a minute
    Edit2: nope, still get invalid device def. when trying to update, still freezes on startup
  12. The Following User Says Thank You to Ice For This Useful Post:
  13. #7
    29
    Let's see is some one can jump in a help figure this one out....I'm out of ideas.
  14. The Following User Says Thank You to pluto30306 For This Useful Post:
  15. #8
    Ice
    I think i just need someone with an actual 2100max US model to copy off their software and zip it up for me
    the 2100max software you posted, im pretty sure ive downloaded it, and its the EU version so everything under version is for a european model
    and im really not sure why your 4350 software wont work
  16. The Following User Says Thank You to Ice For This Useful Post:
  17. #9
    29
    OK...here is the ORIGINAL 2100 Max software...it's version 6.5. Load this and then try to update via fresh maps. http://www.mediafire.com/file/05dmgm...nalMN65-38.rar
  18. The Following User Says Thank You to pluto30306 For This Useful Post:
  19. #10
    Ice
    OK, it wont update past MN6, but it seems to be working, im downloading Q1 maps to verify, O.o fingers crossed and knock on wood, if this works mass no-homo <3
  20. The Following User Says Thank You to Ice For This Useful Post:
