Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 74
Like Tree7Likes
Thread: SD READY Navigon 2100MAX: Unlock+Shell+Upgrade to4310MAX +TomTom 7.910
  1. #61
    Jan 2012
    Re: SD READY Navigon 2100MAX: Unlock+Shell+Upgrade to4310MAX +TomTom 7.910
    Guidorenato,copied your files to my 2100max's sd card TT work like a charm but no tmc support,but that's no big deal.I do have problem with my Navigon.it will star navigate for about 1 minute and then screen forzen.This happen no matter how many time I reset and I have to use hard reset pressing the power off doesn't do anything.This is a 2100max Canada 310 unit running on 1.0202.0409 firmware.Can you please help!Thank you for your time.
  2. #62
    Feb 2012
    EU
    Megauplod is closed..... can u upload it somewhere else??????????
    luky76 and blabry like this.
  3. #63
    luky76 is offline Corporal
    21
  4. #64
    peterson65 is offline Lance Corporal
    can someone put up a torrent or re-up to a new location?
  5. #65
    Sep 2012
    Is there a way to get some sort of new maps onto my Navigon 2100? I really have very old maps on it.
  6. #66
    Oct 2012
    I've got a Navigon 2110max and there are still the maps on it from when I bought it a few years ago. So now I want to update the maps and I want to add the maps of North America because I'll be going on Holidays there soon so I can use my own system and dont have to rent one.
    Now I've downloaded a lot of files and torrents but I'm not quite sure what to do in the first place. Here is the stuff I already got:
    Upgrade 21xxmax.zip (With two folders in it called UpdateME_2100_MAX and Upgrade 21xxmax ó NAVIGON 4310)
    Navigon Europe Q3 12 (With 4 folders: GTA City Models Q3.2012, MAP Q3.2012, NFS Previous Versions and NFS Q3.2012)
    Navigon North America Q1 12 (With 2 folders: map and poi)
    My system is a Navigon 2110max with Version 7.0.13 according to Navigon Fresh.
    So my Questions now are:
    Do I have to update my system before applying new maps? And how do I do it with the files I got?
    Can I have North America & Europe on the same SD card or do I need two seperate ones?
    Is applying maps just copy&paste the .map files on my Navigon?
    Thanks for any help, step by step instructions would be really cool! I'm not new to jailbreaking/cracking soft- & hardware but I just dont want to mess up my Navigon because I need it for my job. So thanks again.
  7. #67
    rhakim is offline Private
    hi
    I have a navigon 2110 max.
    I lost my sd card during the last holiday, and now I need it.
    So i wanted, to copy the "sd ready file" dowloaded for this forum, to my new sd card,.
    Will it work with an empty sd card or do i need to find an original backup before copying the "sd ready card" contents ?
    Can someone upload again the pack sd ready.rar please
    Please help me
    Thank you for all future replys
  8. #68
    Guidorenato's Avatar
    Guidorenato is offline Command Sergeant Major
    202
    I reload the package sd ready
  9. The Following User Says Thank You to Guidorenato For This Useful Post:
  10. #69
    pmaiden5 is offline Captain
    525
    126
    Many Thanks Guidorenato
  11. #70
    Feb 2011
    It says download permission denied? Have new links?
