SD READY
Navigon 2100Max Upgrade To 4310Max
Version 7.4.7 Build 806
Unlock and Pseudo Desktop Installation
TomTom 7.910 Installation
City View 3D, Landmark View 3D, NAVIGON MyRoutes, Reality View Pro, Lane Assistant Pro, Panorama View 3D, Premium TMC, Spoken TMC, TMC Routing Info, CurveWarner, Clever Parking, POI Click, Text-to-Speech.
PWD :Guidorenato
- Unrar the file
- Copy the contents of the folder on the SD (SDHC 4 or 8 GB) View picture:
- In the folder -> Mappa TT put the map file (the file, not the folder)
- In the folder -> Navigon -> map: Put file.NFS and map files that you want
- Insert SD on the Device
Navigon MAPS:
Navigon MAPS Q1_2011
TomTom MAPS:
Here the compatibility list.... you put a map with the version 7.xx. ..: -->CLIK
Here the maps: -->CLIK
To activate TT map using " Easyusetools"
TomTom GPS settings:
- NMEA
- 57600
- NMRX2020 Driver
Pseudo Desktop I made up style NAVIGON
hello,
i installed this on a 2110 max and the navigon software is working fine, but the TT can't find a gps. do i have to use the port splitter? can you help me with the configuration, please.
thank you very much, it works.
sigi
thanks for a cracking download, respect man
got the navigon working great but can't get tomtom going
am unsure as don't speak Italian
I presume I have to download tomtom maps?
If so where do I put them
any recommendations/links
help
THANK YOU ....
well, navigon is working great........... also in my town in Greece......
My questions..??
Plz tell me which map to download for TomTom ex greece... and where to put the files in which folder and how to install tom tom.......
2. How can i add also iGo to the tstart screen i see there are two more empty spaces...
thanks
Best regards,
UniC
For TomTom Maps:
See first post and the post above your.
For Igo:
I do not recommend using it on Navigon device.
The use of Igo (combined with the Navigon and TomTom) change the memory settings, then do not work anymore Navigon and TomTom.
Must be the script for the memory settings of all programs in this release is not expected.
hi all
part 2 is deleted can someone please upload it again?
by the way what is the date of navigon maps?? does anyone knows it?
king regards
stan
Part 2 is not deleted ! !
