Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
Thread: Official Upgrade for the 21xx Max/5100 Max to 4310 Max
  1. #51
    Sep 2011
    Re: Official Upgrade for the 21xx Max/5100 Max to 4310 Max
  2. #52
    Mar 2012
    Correct me if I'm wrong, but if it costs 70 British pounds to download from Navigon's website...this is illegal (stolen) software, right?
  3. #53
    Nov 2011
    Angry Re: Official Upgrade for the 21xx Max/5100 Max to 4310 Max
    Quote Originally Posted by crypkema View Post
    OMG... You're such an idiot...
  4. #54
    May 2012
    OK. I downloaded the file from the new link and the archive contains 2 folders:
    UpdateME_2100_MAX
    and
    Upgrade 21xxmax o NAVIGON 4310
    Could you please tell me exactly what I need to do to upgrade my 2150 Max using the official updater from navigon. ie. where to extract which folder etc.
  5. #55
    Apr 2011
    I also tried to do an upgrade. The map works, the program works, but I cannot get the GPS to work. First I was like the GPS did not even try to connect.
    Then I thought... wait a minute, I have not just a UserSettings.Default, but also a UserSettings.xml! So I checked out the usersettings.xml and that one also had GPS settings. I changed it to the right numbers (by comparing my backup), and then it started looking for GPS, but it still cannot find any. It stays at "0".
    It is a GPS2100MAX with SDcard. Any hints would be greatly appreciated. Maybe someone can tell me more about usersettings.xml? Why is that one not mentioned in this manual?
    friendly greetings,
    Demesmaeker
  6. #56
    hello i need this file , can help mee
  7. #57
    Dec 2011
    Quote Originally Posted by yoppi View Post
    Here it is.
    Could you please upload it again that word_sat file.
  8. #58
    Dec 2011
    Quote Originally Posted by demesmaeker View Post
    friendly greetings,
    Demesmaeker
    Same problem. Have you resolved the problem till know, can you help me also?
  9. #59
    ckk_123 is offline Private
    Feb 2013
    Hey guys
    I did everything in the first post, and i got everything to work. But after i post the address (doesnt matter which map), the map turns white, why does it do that?.
    And i have the newest map. I copyed my old map folder to the navigon.
    its says further more: Application Navigon.exe has performed an illegal operation and will shut down. If the problem persists, contact the program vendor
    Program: navigon.exe
    exception: 0xc0000005
    address: 0037F238
  10. #60
    Feb 2013
    Hello guys...
    I did this upgrade and it went fine until, i used the compiled version. The map that is in the compiled version is district Columbia q1 2009, and that works fine. But when i try to copy the europe mn7 & mn8 q4 2012 maps, the it doesnt works. I put the address and the map is white and doesnt show anything, and i can only hear the voice.
    Please help guys!
  1. 20th March 2012, 12:44
  2. 7th January 2012, 14:40
  3. 1st January 2012, 15:38
  4. 17th September 2011, 10:23
  5. 25th March 2011, 15:16
  6. 26th February 2011, 22:48
