Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Official Upgrade for the 21xx Max/5100 Max to 4310 Max
    pluto30306 is offline Corporal
    29
    Thumbs up Official Upgrade for the 21xx Max/5100 Max to 4310 Max
    More info here: http://www.navigon.com/portal/uk/kar...-2150-max.html
    New functions for your NAVIGON 21xx Max/5100 Max.
    Upgrade your device to a NAVIGON 4310 max* – with NAVIGON MyRoutes, Spoken TMC, TMC Routing Info, Text-to-Speech and many other helpful functions.
    Additional Text-to-Speech languages
    New system languages: Add your own language/sounds: Tested with USA Languages/Sounds
    Add your own Maps: Tested with 5100 Max NA Q3 2009 & NA Q1 2010
    Including a new update for Clever Parking and Safety Camera.
    * The Picture Viewer function will no longer be available after the upgrade.
    * The Bluetooth function will no longer be available after the upgrade.
    * Lifetime TMC
    Here is the link to the official upgrade software download: http://www.mediafire.com/file/nzd2zm...d 5100 Max.rar
    Here is the link to the upgraded complied SD only version: http://www.mediafire.com/file/itm4ry... 5100 Max .rar
    Step 1: Download the files (either the upgrade or the complied version)
    Step 2: Format your SD (after making a backup copy)
    Step 3: Copy downloaded files to your formated SD
    Step 4: Copy your perferred version of Maps to the "map" sub-folder (do not mix versions of maps)
    Step 5: Copy your favorite voice files to the sub-folder "sounds"
    Step 6: Before you start, make sure you match your OLD UserSettings.Default settings to the new UserSettings.Default
    <TMC>
    <RadioStationScan>0</RadioStationScan>
    <AutoRecalculation>0</AutoRecalculation>
    <PreferPay>1</PreferPay>
    <TMCPort>1</TMCPort>
    <TMCBaudrate>115200</TMCBaudrate>
    <DRVPrefix>RDS</DRVPrefix>
    </TMC>
    <GPS>
    <Type>0</Type>
    <GPSPort>7</GPSPort>
    <TMCPort />
    <Baudrate>57600</Baudrate>
    <DRVPrefix></DRVPrefix>
    The file is already set for the 5100 Max
    Step 7: Insert your SD and Hard Reset your Navigon
    Compiled version - You are done.
    Upgrade version - Your Device will begin to do the upgrade and may require to be rebooted a couple of times..you'll know you are done when you see the sign on the device to reboot.
    Enjoy!
    Model: Navigon 5100 Max
    SW: MN747-806
    Maps: NA Q1 2010
    Model: Navigon 5100
    SW: MN743-793
    Maps: NA Q1 2010
  2. The Following 4 Users Say Thank You to pluto30306 For This Useful Post:
    peterson65 is offline Lance Corporal
    Re: Official Upgrade for the 21xx Max/5100 Max to 4310 Max
    does this work on the 2100 max?
    Quote Originally Posted by peterson65 View Post
    I've tried it, using the official software upgrade and 2010 Q2 maps, and that didn't seem to work.
    Upgrade went fine, but then it doesn't find any maps...
    Edit: It does work actually! I forgot to put the NFS files in the map directory. Works fine, TMC to be tested...
    i cant seen to get it to work? i rebooted multible times and then it finaly booted but the screen was dim then i get fatal application error , application navigon.exe has performed an illegal operation
    ? i tried the compilled version but i get an error when un raring the file
    can you re-up the compilled version? the file is corrupt
    thanks
    does it work on 3310 max?
    29
    thanks
    I just checked - the first error..is a file check...wont effect the extraction. The second file error is the TMC.NFS file in the MAP folders...since you need to load your maps into that folder anyway you don't need to worry about that file either. Everthing else is working fine in my test. Load your map files and you are set to go, just delete the map files in my folder, when you upload your version on the map you want to use.
    29
    Quote Originally Posted by yamahafazer View Post
    It should...try the complied version first.
  10. #9
    Where do you add the map files to?
    When i boot the 2100 up it cannot find a map. Do you need other files with the UK map?
  11. #10
    29
    Quote Originally Posted by swadd View Post
    All you need is your own maps loaded in the Navigon\MAPS folder along with the NSF files. Don't mix NSF or map versions. Copy all those map files/NSF in the MAP folder. Any version will work...US or UK/EU. Their are links on this site for updated maps. Let's us know if you need further assistance.
    I re-loaded the rar file http://www.mediafire.com/file/itm4ry... 5100 Max .rar
