4Likes
22nd February 2012, 11:22
#31
Re: Navigon 7.7.5 Build 447 for WinCE 5.0 & 6.0
Swedish language and voice for this version 7.7.5, please.
6th March 2012, 09:39
#32
Hi guys does anyone know if this software will run full screen on my 800x480 device?
The Following User Says Thank You to satmaniac For This Useful Post:
9th April 2012, 07:52
#33
Thanks a lot, I'll try this soft
cannot download...can someone give link for malaysia map together with the soft? tq
17th July 2012, 15:38
#36
I have a Chinese double din car unit running Win Ce 6, The program itself seems to work, but it cannot find any maps? is there anything I need to do or configure to get it working on win CE6...... My setup work perfectly on a navigo 4.3" device running win CE 5
18th July 2012, 15:57
#37
can i get the link & also if you have Australian map. Thanks.
22nd January 2013, 22:51
#38
hi please help me out of a problem, i had this version installed on my gps it works great but i cant install the newest maps on it? q3 2011 maps works ok but q3 2012 maps dont work?
13th February 2013, 18:11
#39
need new links, please. THX
30th March 2013, 17:12
#40
