Release name and version (if any): Navigon 7.7.5 Build 447
Requirements: Navigon Software
Operating System: WinCE 5.0
More info: The kit contains a map of Romania (and files for NFS, including Truck) Q2.2011, Romanian language and voice, the last POIs and cameras for all of Europe. The program is set to SDMMC card, port = 7 baud = 57600. For other values please make the necessary changes.
Download Links/Instructions:
if pass: leinad
For North Cross Es515says no maps found. The device is operating system ce6. What changes should be made?
Try it! Is possible to have some good surprise!
Hi Leinad,
Can you run this software on Navigon 2100 (non Max version), I tried this but some how other I can't navigate. After few min. it got hanged, everytime have to restart. I did put right gps port and right baudrate for my version. Any light on this matter will be highly helpful. thanks for all help.
I have got this working on Binatone Z430BT but is there any way I can use english language on this please help
Alanwood
I have also got this working on a Binatone G500 just need to get the English language sorted.
hi
how can i use poiwarner on navigon
i don't find a clean version of poiwarner
Hi.
I managed to start the software on I-Joy I-Route Kompass Plus GPS device but when the menu shows up the screen gets lightly dimmed and the software gets stucked.I mean it gets unresponsive I can't press on any button ... nothing.
Any ideas why this occurs.Any help?
Thanks.
