Thread: Navigon 7110
    Navigon 7110
    I tried to put on the 7.4.3 but keep getting system errors ( i realy wanted this to work but when the maps screen on a navigation, starts it directly crashes with an illegal system erro .) , so i tried to put back the original software but this won't work anymore . system keeps crashing on the double arrow screen .
    can anyone help me on either putting the old one back to work or the 7.4.3 ?
    erro in 7.4.3 is program : navigon.exe
    Exception : 0xC0000005
    adres 00493200
    Thank you
    Re: Navigon 7110
    i have the same problem. whar to do ??
    jstduit is offline Staff Sergeant
    67
    Re: Navigon 7110
    if you made a backup using navigon fresh put you old version back on the sd card then hook up to computer open navigon fresh click on backup then click on restore. if you didnt make a back up make sure the settings match your device. also make sure you have the maps and nfs files in the right location. the right folder is navigon/map
    Beartraxx33's Avatar
    Beartraxx33 is offline Sergeant First Class
    Ottawa, Canada
    117
    19
    Re: Navigon 7110
    does anyone have a sd card backup for this navigon model. or a link to the software i can download. Any help would be apreciated.
