Page 1 of 11 123 ... LastLast
Results 1 to 10 of 108
Like Tree9Likes
Thread: MN 7.4.3 with TMC Pro - TS7000T/71xx Edition
    fraggy is offline Lance Corporal
    Description:
    SD-Ready version MN7 (7.4.3 from 2310) with TMC Pro
    Copy the "SD" Folder content to your SD Card and overwrite all the settings and dll files in the NAVIGON directory with included files in 7000/7100 folder.
    Copy the language you want (see download below) to NAVIGON\language_files and sound files to NAVIGON\sounds
    place your own maps in the NAVIGON\maps folder
    All .nfs files are included in this package (Q1_2010 and Q2_2010 Version)
    How to change the language?
    In Navigon go to Optionen -> Einstellungen -> Allgemein -> 3 von 4 -> Sprache. And change to your preferred language
    Alternatively after first start open NAVIGON\Settings\UserSettingsLanguage.xml with text editor and change "ger-DEU" to "eng-USA" or "eng-GBR"
    What do you need?
    - language files (german users don“t need this)
    - sound files (german users don“t need this)
    - newest MN7 maps
    Features:
    City View3D, Landmark View3D, MyRoutes, Reality View Pro, Lane Assistant Pro, Spoken TMC, TMC Routing Info,
    Real Roadsign Pro, CurveWarner, Clever Parking, POI Click, Text-to-Speech, Premium TMC
    NOT INCLUDED: Panorama 3D, VoiceControl, Bluetooth
    Tested Devices:
    - Becker 7827, 7928, 7977, Be-Z101, Z-103, Z201 [7000T Version]
    - Medion PNA 465t, PNA 470, P4410, P4210, P4425, E4430, E4435, P5235, P5430 [7000T Version]
    - NavGear GT43 [7000T Version] !only with NL-316R TMC Receiver!
    - Transonic TS 7000T [7000T Version]
    - Navigon 7100, 7110 [71xx Version]
    - Chicago 9000 [71xx Version]
    - Bluemedia BM6600 [7000T Version]
    - SUNGOO 43.1 [7000T Version]
    Download
    MN7.4.3 with TMC Pro - TS7000T/7100 (Rapidshare, 193MB)
    MN7.4.3 all Language and Sound Files (Rapidshare, 200MB)
    THX to ObiX, KaenGuruH, eduardo1, 2much, michaelm_007, djmokel
    Re: MN 7.4.3 with TMC Pro - TS7000T/71xx Edition
    Hi!
    Thanks for the upload..
    I'm a newbie and got a question , how do I change the language to English??? Right know is in German..
    Hi
    I“ve added all language and sound files in the first post. Download them and copy the files you need in the folders.
    bob514 is offline Private
    Can i use this on a 7100 in USA? Do I have to modify something to use USA+Canda maps/POIs? Can I keep English, french, spanish voice options?
    Thanks for the sound files... They work grate..
    Keep the good work....
    Quote Originally Posted by bob514 View Post
    Yes they do, I got a 7100 and I just installed this today and use it with the 2010 USA maps and it work...!
    did everything as explained, put my US maps in root directory (like on my original card), programs starts loading, some german questions for km/miles and 12/24 h options but then I get a mesage in german:
    "es konte keine Karte gefunden werden" which Google translates into :" Konte is no map found"
    I'm guessing the program cannot find the maps? where should I put them? I believe these are q3 2009 maps
    I can't even get to change the langua option yet!
    got a little further, placed maps in /maps folder, but all my messages are in german!
    where is language option?
    I do notice in my lower right box "allgemein" where I get to choose between miles/km, 12/24h and Petra or Sabine voices I have 3 setup lines without ay options and pressing the "information wrench" crashes the navigon
    Hi Bob
    you have to download the language+sound files too. Copy the language you want to NAVIGON\language_files and sound files to NAVIGON\sounds
    place your new maps in the NAVIGON\maps folder
    Alternatively open NAVIGON\Settings\UserSettingsLanguage.xml with text editor and change "ger-DEU" to "eng-USA"
    Hi
    fraggy
    So far everything is good except that the Zagat poi are not showing up! any ideas, I install them in the poi folders, but when look in my navigon 7100 for poi near me it only show the one in the map no Zagat.
    Any idea on what to do??
    Thanks.
