Results 1 to 10 of 13
Thread: Navigon 7310
    Slivkosi is offline Private
    Navigon 7310
    Hy i have navigon 7310 and i had a accident with files on it and i would like to know where can i get software for navigon. I tried Navigon fresh but no lock it says that it needs files but i deleted unfortunaly.
    Any help??!!
    Re: Navigon 7310
    You need navigon 7.4.2 PNA google it then look for maps on here
    jstduit is offline Staff Sergeant
    67
    Re: Navigon 7310
    Quote Originally Posted by Slivkosi View Post
    Any help??!!
    here is alink to download version 742 build 802 for 7310 http://www.mediafire.com/file/imyz2z...-73x0_72x0.rar
    Re: Navigon 7310
    Thank you very much ))))), do you maybe know, which file is register file, because i cannot download maps from navigon fresh, because previous software was register on my username?
    67
    Re: Navigon 7310
    <software>
    <version>7.4.2</version>
    <build>802</build>
    <brand>NAVIGON_EU</brand>
    <platform>7310SD</platform>
    <productprefix>EU</productprefix>
    <copyright>NAVIGON AG, Copyright (c) 2009</copyright>
    <productid>EU6S1JW19G3Y3SD</productid>
    <id>G10N001.01ECXCA9B</id>
    <gts>40|54|19|27|4|109|3|146</gts>
    </software>
    this what your version.xml should read. as long as it says 7310 and product id you should beable to download from fresh. if not try logging on navigon web site with your name and pass you used to setup account and click on software if it says a update is available for your device then download it as a zip file dont use fresh to download it. then extract the zip file to a clean sd card then open fresh and see if you can download maps.
    67
    Re: Navigon 7310
    try this i believe this is the original software that came with the 7310 http://www.mediafire.com/file/zhnowwlo2dw/NAVIGON.rar
    Pac-Man is offline Lance Corporal
    Re: Navigon 7310
    It didnĀ“t work. Help!
    DeadEnd2 is offline Private
    Apr 2011
    Re: Navigon 7310
    Dear all,
    I'm new to this board, so sorry if I cannot create my own thread, but the subject is really close to Slivkosi's problem.
    As my european Navigon 7310 is going abroad for a moment (USA... soon ), I managed to have US maps.
    Unfortunately, putting maps at the SD root doesn't give access to these maps for the GPS.
    Maybe it is just a newbie/simple question, but this will help me a lot if you could give me a hand.
    Regards !
    Jun 2011
    Re: Navigon 7310
    thx maar weere
    67
    Re: Navigon 7310
    Quote Originally Posted by DeadEnd2 View Post
    Dear all,
    Regards !
    the maps have to be in the map folder and the nfs files for those maps to not in the root of the sd card. if you don't have a big enough sd card (a 8gb will work). then you will have to delete the maps and nfs files in the map folder and install the new maps into the map folder. if you have a 8gb card then all you have to do is inside the map folder make a new folder call it US Maps then copy all the maps and nfs files to that folder. since you are only going for a short time and you don't need all the maps just put in the ones you will need but you will still have to puat all the nfs files that come with those maps in there. make a back up before you start
