Thread: Navigon 7310 - Updating maps issue
    DeadEnd2 is offline Private
    Apr 2011
    Dear all,
    I've tried to install Q1.2011 maps on my European Navigon 7310, and it is not working as it should.
    Here's what I've done:
    - connected the device to a PC
    - edited the /NAVIGON/MAPS folder and
    - copied DrawSettings.nfs and Terrain_NA_USA.nfs
    - copied Landmarks_NA.nfs
    - copied California.map, NavigonRealityView_NA.nfs, Phoneme_NA.nfs, TMC.nfs (and rename the previous as TMC_old.nfs),
    - edited the /NAVIGON/POIS folder and
    - copied USA_CA_ZAGAT.pom and Zagat.nfs
    Then unplugged the device properly, and changed the map Europe to USA.
    The device restarted, and I tried to visualize the US map... with no luck: only a blank page.
    So maybe I missed something ?
    Can I install the files to a uSD card, instead ?
    What is the structure of the file, at SD root ?
    Hope you could help me, I coming in USA quite soon.
    Thanks in advance !
    Best Regards
    Apr 2011
    Re: Navigon 7310 - Updating maps issue
    First thing I should have noticed: maps files are ".maps" with Q1.2011 archive I've found here... and the files on my device are ".nfs" files.
    I think I missed something...
    A little help would be very appreciated !
    Regards
    Apr 2011
    Well, it seems Navigon deals with ".map" files too.
    I connected the device to the PC,
    - removed most of the .nfs map files (France, and so on...),
    - then copied to folder \MAP\, California.map, Terrain_NA_USA.nfs,
    - changed the TMC.nfs file to the new one provided
    - created folder Landmarks, and put Landmarks_NA.nfs
    Then restart the device, switched to Navigon_An_USA_Q1.2011 map, reboot, and... voilà !
    The map of California was here, zoomable.
    Next, I will add other files, like POIs, Phonemes and so on !
    I'll keep you in touch !
    Regards
  4. The Following User Says Thank You to DeadEnd2 For This Useful Post:
