Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Like Tree8Likes
Thread: Navigon MN8.01 Build 2742 - Flow
    Leinad is offline Sergeant First Class
    Navigon Land
    101
    Navigon MN8.01 - Flow
    Mirror Navigon MN8.01
    if pass: leinad
    788
    151
    Re: Navigon MN8.01 Build 2742 - Flow
    Hi my friend :-)
    Is this to WM to??
    kyritsis is offline Private
    Jul 2011
    Hello and thanks for this build.
    I installed it on my 8410 and it works fine except that it does not display landmarks, panorama view, city 3d and real city 3d.
    Maybe I am doing something wrong or is it that perhaps this version does not support these features?
    Very nice interface, however.
    Navigon Land
    101
    City 3D work. Panorama View & RealCity not included in this version. Panorama only in Premium Version.
    Navigon Land
    101
    Thumbs up Re: Navigon MN8.01 Build 2742 - Flow
    Release name and version (if any)Navigon MN8.01 Build 2742 - Flow
    Requirements: 128mb RAM
    Operating System: WinCE 6.0
    More Info:
    http://www.navigon.com/portal/int/NAVIGON_Flow/index.html?xtatc=INT-1-0||13662530
    Download Links/Instructions:
    Kit settings: Romanian, ResidentFlash, port=1, baud=38400, will be open with MN8.exe without Map and POI Folders.
    Kit-Einstellungen: Rumänisch, ResidentFlash, port = 1, baud = 38400, wird offen mit MN8.exe ohne Karte und POI-Ordner.
    Navigon 8 Flow
    if pass: leinad
    For Quit button (thanks @mischka202) please make this changes in Navigon/quicklaunch.ini value: (button orange in left part - in right part is screenshot button).
    Für Beenden -Taste (Danke @mischka202) stellen Sie bitte diese Änderungen in Navigon / quicklaunch.ini Wert: (Button orange in linken Teil - in rechten Teil ist screenshot-Taste).
    [Settings]
    Width = 20
    Height = 20
    Position = BottomLeft
    Color = FFA500
    Command = ResidentFlash\Navigon\Quit.exe
    sputnik likes this.
  6. The Following 3 Users Say Thank You to Leinad For This Useful Post:
    Marcelo Claudio is offline Private
    Sep 2011
    Works in navigon n70 premium but without some funcions
    OFF buttons does not work..how to solve this?
    Navigon Land
    101
    @Marcelo Claudio
    Modify the file .mscr (mn8.mscr and quit.mscr) where replace ResidentFlash with My Flash Disk).
    Sep 2011
    Dear Leinad
    thank you so much...
    but i cannot find those files on my folders...where are they located?
    regards
  10. #9
    Sep 2011
    dear leinad...final i found the problem. i was using other flow available on the net....
    the onde on this this post does not boot...
    can you help me ? maybe my email? we finall solution found we can post in the forum solution for 70 premium. is it ok?
    regards
    ps - i can give tou a dropbox of the other flow
  11. #10
    fedor079 is offline Lance Corporal
    Sep 2011
    Quote Originally Posted by kyritsis View Post
    How did you install on 8410? (please write step by step). My one doesen't start.
  12. The Following 2 Users Say Thank You to fedor079 For This Useful Post:
