Results 1 to 7 of 7
Thread: Omnitech, Navigon wont find GPS signal
    I've been trying to get Navigon on here for days, finally have an the gps signal will not work =/. I've searched the forums for fixes but cannot find one, my omnitech gps does run windows ce 5.0 and i used
    joking742's Avatar
    67
    Re: Omnitech, Navigon wont find GPS signal
    Quote Originally Posted by klenz View Post
    Just download and add map folder...(from my omnitech)
    Prodeje79 is offline Private
    Quote Originally Posted by joking742 View Post
    what date are these maps?
    joking742's Avatar
    67
    It does not contain maps....newest out for NA are Q310
    Jan 2011
    United States
    sim so dep
    Improbable submit! This might help a lot of folks find out about this matter.
    linkwheel viec lam
    Sorry, double post.
    Jan 2011
    United States
    sim so dep
    linkwheel viec lam
    Sorry, double post.
    Sep 2011
    i had similar problem in my omnitech ..i change the usersettings.xml file (under-settings folder).. change the GSPport to 1 and baudrate to 4800
    so it will be
    - <GPS>
    <Type>0</Type>
    <GPSPort>1</GPSPort>
    <TMCPort>4</TMCPort>
    <Baudrate>4800</Baudrate>
    <DRVPrefix />
    </GPS>
    after that save it on sd card plug it in and you should be alright. mine picked up in 2 secs.
