Thread: Porsche Design Navigon
    I got a "Porsche Design" P9611 GPS from a friend. There's no software included, and as I understand, all software and maps must be on a SD card. What version of Navigon software will work on this model, and where to get it? Grateful for an answer folks
    jstduit is offline Staff Sergeant
    67
    Re: Porsche Design Navigon
    what is the processor speed how much memory does it have what is the screen resolution need to know these thing to tell you what software may work
    67
    i found this article on your device
    Sounds like the P9611 will come with a removable battery and the cone shaped windshield mount will have integrated speakers inside. The 4.3″ screen provides a 16:9 viewing area where you can operate the Navigon MobileNavigator 6 software.
    Instead of using traditional chip GPS SiRF III, this PND uses the moon chip µ-blox Antaris4 SuperSense. Let us hope that it will be as sensitive as SiRF III.
    The system will come preloaded with locations of radars and such to keep you out of trouble but we don’t for which country.
    Features
    •Receiver GPS integrated with chip GPS µ-blox Antaris4 SuperSense
    •Receiver RDS/TMC integrated for information traffic in Premium
    •Touch screen 4.3 inches TFT 65 536 colors with the format 16:9 and of resolution 480×272 pixels (WQVGA)
    •Processor INTEL Xscale PXA 270 To 520 MHz
    •Co graphics processor INTEL 2700G
    •64 MB of RAM and 64 MB of ROM
    •Port SD/MMC
    •Mini USB 1.1
    •Kit Free Hands Bluetooth
    •Battery removable Li-Ion of 1400 mAh
    •High speaker integrated in the PND of 0.4 W
    •High speaker integrated in the support of 1.7 W
    •Dimensions : 12.3 x 8.2 x 2 cm
    •Weight : 250 grams
    •Microsoft Windows CE.net 5
    •Software of navigation Navigon MobileNavigator 6 with information traffic in RDS/TMC Premium and warning signal of radars integrated
    •Navteq maps of the 37 countries of dated Europe 2006.Q1 stored on chart SD 2 GB.
    •MP3 player (with listening of MP3 at the same time as navigation GPS)
    marc2040 is offline Lance Corporal
    The Porsche is a branded Navigon 8110 and upgraded 8310.
    So you can use Navigon 7.4.3 build 201 480x272.
    Have a look at If you have any question, don`t hesitate.
    You can contact me also on (always the same username marc2040)
    Please write in simple words because I“m german and my english is not as fluent as my native language
    Only Mn 6.2 works ok you can use v6** Q3-2010 maps.
    Because this nav using oder hardware !! no sounds possible with v MN 7xx and Igo.
    Also Navigon gives no software update for>> Porsche Design <<Navigon anymore.
    (i have used every trick no luck ) Greetings
