Thread: Where do I put the maps?
    I have got a newly bought Navigon 70 Plus.
    Information that I have obtained from the device is among other things:
    Navigon PL70 23
    Version 7.6.4 (build-1165)
    Maps are 2010-Q2
    I have downloaded Sweden 2010.Q4, but I don't where to put it. Can I run it from an SD Micro-card? Which folder Structure should I use?
    /Bengt, Sweden
    Re: Where do I put the maps?
    Quote Originally Posted by qzgbt5 View Post
    Navigon PL70 23
    Maps are 2010-Q2
    /Bengt, Sweden
    just place it under under navigon/map on the device
    or place it on the sd card map/...
  3. The Following User Says Thank You to moksa For This Useful Post:
