Thread: How do I change fonts in MobileNavigator 7.4.3.793?
    I've got MN7 running fine on a Win CE 5 320X240 machine. However the current font being used gives me a lot of 99... (three periods is the problem) in items such as ETAs and other time indicators. How do I change fonts to fix this situation so that I can see entire time values? Is it a matter of putting a different font file in a certain folder? I've tried a font file (ex. tahoma.ttf) in a few different folders, but nothing changed. Thanks for any help here!
    tourist is offline Lance Corporal
    Re: How do I change fonts in MobileNavigator 7.4.3.793?
    You need to use MN6Resourceview to edit several template.dat files inside Mobilenavigator.res. Try to change the 0x10 value in template8.dat from 0B to 09.
    I appreciate that! I'll give it a try. First with Template8 and then try others if that doesn't do what I need!
    teerak2uk is offline Staff Sergeant
    Lincs,UK
    81
    41
    Hi guys where can i get the mobilenavigator software for wince4.2 or 5.0 from
    many thanks
    marc2040 is offline Lance Corporal
    Go to There you can get all versions for free
