Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By qwer
  • 1 Post By rexton270
Thread: how i can add maps for sony NV-U93T
    how and i can add maps fpr NV-U93T and where i can get them?
    immediantly i need Estonia country map
    reis_0556 likes this.
    astraclub is offline Lance Corporal
    Dec 2010
    Re: how i can add maps for sony NV-U93T
    I bought NV-U93t and was very happy in Europe and it is the best ever looking unit, But when i want to do a map update, sony told me that no more map update?
    What?? Thats disgusting and very bad from Sony, I spent 350 Euro and no more map update?
    I just moved to US and was looking for a US map update for this and same thing happened. No US map for this unit here in US.
    I sent a mail to SONY and they replied that no map for this?
    Now what should i do?
    Should i just go to SONY HEADQUARTER and return the unit with a letter.
    Is there anyone with this update?
    Any map update for sony NV-U93t? Any US map?
    All help is appreciated!
    debeliamark is offline Sergeant Major
    www.mivamark.net
    165
    242
    The best way is to forget about SONY ... and use althernative SW inside the unit -> for example - latest iGo ( named Primo ) is just fine.
    How to do it?
    Download needed tool from here
    Backup all from mounted volume ( just for prevent headaches ) before to play with your PNA .
    Copy extracted archive inside mounted volume.
    Change navigation sw with editing of main.ini
    WBR, DebeliaMark, BG
    P.S. to catch connection between PC and PNA as i remember Sony Nav-U must be with charger connected.
    P.S.2 do not forget to press Tnx button
    Dec 2010
    Hi Debilia Mark
    Thanks for the message and let me try these and trust me, if all these comes to work,
    I will press THANK button twice,
    So, I download the link and I also download the mountain volume, which one to work first, is there any step wise process?
    If i get mine working I will definately make one and upload here!
    Dec 2010
    Hi
    I tried to follow the procedure and when i uploaded mountain volume and reset my Sonu NV-U93T, the system came on but there is a message :--
    "Fatal Error: Initialization error: no language files were found"
    I can only press "OK" button and system will go dead.
    I tried to connect the device on my win7 laptop but guess what- laptop is not reading/connecting Sony Device now.
    so this is where i got stuck :-()
    Any help please--I am so close but still so far....
    can someone help
    rgds
    D
    teeyaha is offline Private
    May 2011
    Exact same problem. Please help.
    File I downloaded didnt have any language files included :-(
    Quote Originally Posted by astraclub View Post
    Hi
    can someone help
    rgds
    D
    Dec 2010
    I am still finding it hard to fix "Initilization error: no language files were found" error
    I also have the issue of not connecting my Sony device to computer so that i can reload backup on to sony
    rgds
    ASTRACLUB
    Jun 2011
    Do I put the files (sony unlock) in mounted volume folder in the device's memory or on the sd card. After this do i do the regular thing with the new software(put it on the sd card) and how to set the nav sw in main.ini . Sorry but i'm new at this and still learning
    Nov 2011
    rgds
    ASTRACLUB
    Hi, Sony nv-u isn't supported beyond WinXP. when running W7 try set compatibility to XP. But tbh, I think there's very little chance for success...
    realmadrid likes this.
