Thread: Navigon 3300max +micro sd
    My Navigon don't show maps from sd card. What should i do?
    Re: Navigon 3300max +micro sd
    copy all system to sd card, not only maps
    First look in map NAVIGON/MAP in your back-up than make on your sd card a map : Navigon submap : MAP just like you can see in the backup than copy the files to the MAP also the NFS in the same map (not the map NFS but the submaps)
    is it possible to instal garmin soft to this nav?
    Jan 2012
    Ronaldo began kicking a ball close Gold WOW to when he was three. His skill
    was apparent then and by 10 many years old
