Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Like Tree3Likes
Thread: Navigon for WinCe 5.0 GPS
  1. #21
    KingKoopa is offline Lance Corporal
    Re: Navigon for WinCe 5.0 GPS
    Can I do it the other way around.
    Can I install a Navigon on a Magellan Maestro 4040?
  2. #22
    willowgate is offline Corporal
    16
    Question Re: Navigon for WinCe 5.0 GPS
    Hi Dupree,
    I have a little problem. I don't know why but when I change a setting in the GPS Option and I restart the GPS, the setting is not saved. Also, the language and time format are always asked when I start the GPS, the settings are not saved.
    Regards,
    Jonathan
  3. #23
    dupree is offline Sergeant
    31
    Hi willowgate,
    I`m not sure about that.. Have you checked the UserSettingsLanguage file?. If the setting is not changed one possibility is may be the archive mode of your file is disabled. What you can do is to right click on the Navigon Setting folder (or the UserSettings and UserSettingsLanguage files), select Properties, check on the Archive option and disable (uncheck) the Read-Only mode.
    Cheers
  4. #24
    16
    Hi Dupree,
    I checked and the archive option is "checked" and the read-only is "unchecked". The file UserSetting doesn't change on the disk, only in memory. Any other idea ?
    Also, what is the "Service Activation" in the GPS options ?
    Do you know if there is a POI Q2 2010 North America, like the MAP or only POI Q1?
    Thanks for your time !
    Regards,
    Jonathan
  5. #25
    16
    Hi Dupree,
    My previous GPS software (Destinator 9) was execute on the "Residant Flash" and the map was on the "SDMMC" (my memory Card). The Navigon software is bigger and all the files are on the "SDMMC". Do you think is the source of my issue ?
    Also, do you know if the "Building 3D" are available for North America or only for Europe ?
    Again, thanks a lot.
    Regards,
  6. #26
    16
    Talking Re: Navigon for WinCe 5.0 GPS
    I solved all my problems using this version "Navigon MobileNavigator 7.4.3 build 793 for PDA [320x240]" and I added only the file Hardwarelayer.dll from VARJOMIES.
    Link:
  7. #27
    joking742's Avatar
    66
    I'm running Navigon 7.43 on an Insignia cnv43 without an unlock (using autorunce.exe and usershell startup screens... have everything but bluetooth/tmc working at this point)
    Does anyone know what settings to change in ApplicationSettings.xml that causes 7.43 to shut down "battery level critical" on start-up with ac/usb attached.
    Works fine if I boot up on battery (no message/shut down) and add ac/usb once software running,(battery is fully charged)
  8. #28
    jstduit is offline Staff Sergeant
    67
    Quote Originally Posted by joking742 View Post
    you can try this setting <USBModeExitBehaviour>5</USBModeExitBehaviour>
  9. #29
    Hello!
    I have a Comex NVA-03560 GPS system that I would like to use with Navigon.
    As I am a complete noob on changing these GPS systems I was hoping someone here could help me out how to run Navigon on this GPS...
    Here are some technical details about the GPS:
    Hersteller 	 Connex
    Modell 	GPS NVA03560, GPS NVA-035-001, GPS NVA-0350
    Prüf-Datum 	12-2009
    Serien-Nr 	009727
    Serien-Nr Gehäuse 	90090209149
    CPU 	Samsung S3C2416, 400 MHz
    HW 	C16L54P04G756_A03
    RAM 	64 MB SRAM DDR2
    Flash 	2 GB NAND-Flash
    MicroSD 	8 GB max
    USB 	Mini-USB v2.0 als Massespeicher
    Betriebsystem 	WinCE NET 5.0 Core, V5.0.04
    Hersteller 	 Connex
    Prüf-Datum 	12-2009
    Serien-Nr 	009727
    RAM 	64 MB SRAM DDR2
    MicroSD 	8 GB max
    Hersteller 	 Connex
    Prüf-Datum 	12-2009
    Serien-Nr 	009727
    RAM 	64 MB SRAM DDR2
    MicroSD 	8 GB max
    320 x 240 pixels 16bit
    Anyone knows if this is possible?
    A big thanks for helping me out!
    Sebastiaan
  10. #30
    Quote Originally Posted by willowgate View Post
    Link:
    Could you please post a link to "Hardwarelayer.dll" from VARJOMIES ???
    Many thanks in advance...
