Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Like Tree3Likes
Thread: Navigon for WinCe 5.0 GPS
    willowgate is offline Corporal
    16
    Question Navigon for WinCe 5.0 GPS
    I would like to know if is it possible to install/run Navigon on a GPS using WinCe 5.0. My GPS use Destinator software presently.
    - Instructions ?
    - Download Link (Software and map for North America) ?
    Regards,
    Willow Gate
    raf67 likes this.
  2. The Following 5 Users Say Thank You to willowgate For This Useful Post:
    dupree is offline Sergeant
    31
    Re: Navigon for WinCe 5.0 GPS
    Hi..
    Yes it is possible to run on your Wince 5 GPS.. but first you need to unlock your device before installing the Navigon..
    In the Unlock GPS forum you can find many threads on how to unlock Wince 5 device..
    For the navigon SW you can go to this thread http://gpsunderground.com/forum/show...T-71xx-Edition or try to google in other sites.
    Cheers
    kokinos and ahmadbob like this.
  4. The Following 2 Users Say Thank You to dupree For This Useful Post:
  5. #3
    16
    Question Re: Navigon for WinCe 5.0 GPS
    Thanks for your response. I will unlock my GSP and I will try the 7.4.3 version. But, just to be sure, the 7.5.2 doesn't works on WinCe 5.0, only on WinCe 6.0 ?
    Regards.
    Willow Gate
  6. #4
    31
    Hi willowgate..
    From other responses, 7.5.2 doesn`t work on Wince 6.0. I`ve never tried it but 7.4.3 works fine on my Navman S50 (Wince 5.0)
    Cheers
  7. #5
    16
    Thanks for your response. I will retry the 7.4.3 tomorrow. I did a quick test yesterday, but I got an fatal application error when I started the Navigon.exe
    Do you know if I need to change some config file before using the package or running the navigon.exe file ?
    Program: navigon.exe
    Exception 0xc0000005
    Address: I forgot the code.
    Regards.
    Jonathan
  8. #6
    Could someone tell me if can install this software (interface and maps) on a Nokia 500 running (Windows CED 5.0) and where/how can I get download it from?
    Thanks so much!
  9. #7
    31
    You can try these two files to fix the errors. Just replace the original files with these new files..
    1) Attachment 835
    2) VARJOMIES MN7 SETTINGS.rar
    ~credit to Varjomies
    Cheers..
  10. #8
    31
    Quote Originally Posted by cruzzy3 View Post
    Thanks so much!
    Hi cruzzy3,
    I`m not sure about that because I`ve never used Nokia... but you can give a try or you can ask other experts on the other thread http://gpsunderground.com/forum/show...T-71xx-Edition.
    But from what i read in other forums, Navigon can be installed on Nokia 500..
    Cheers
  11. #9
    16
    Hi Dupree,
    I tried your fixes but I got the same error, address: 0015A400. Any idea ?
    Regards,
    Jonathan
  12. #10
    16
    Hi again,
    I think my GPS support only the resolution 240x320. I would like to know if the Navigon 7.4.3 can be use in this resolution ?
    Regards,
    Willow Gate
