Results 1 to 10 of 11
Thread: Navitel Navigator v5.1.0.47 For WinCE
    trosten is offline Sergeant
    Jan 2012
    Tehran-Iran
    30
    Hi dear friends. you can download Navitel Navigator v5.1.0.47 For WinCE at this link:
    Hotfile.com: One click file hosting: Navitel Navigator 5.0.4.0 WinCE - hamta Corp. Edition by Carbuncle.rar
    Mirror:
    http://www.uploadbaz.com/wzoal3gsz76r
    http://www.mediafire.com/file/cmd6ds...0Carbuncle.rar
    it is unlocked and No map included.
    Credit Goes To Carbuncle
    regards
    Trosten
    New version of Navitel 5.1.0.47: priority lanes display, interactive interface and other changes
    What’s new in Navitel 5.1.0.47:
    Displaying of priority lanes at maneuver.
    Navitel will help to get ready for the next maneuver in advance, indicating the right lane for changing. User can choose, whether the hint for priority lanes at maneuver will be indicated at the top or at the bottom of display, or deactivated at all in the program settings.
    Sensors of “Navitel.Traffic” service and satellites information are updated.
    Sensor “Navitel.Traffic” now displays information about traffic jams in the city in points-from one to ten, and sensor “Satellite” shows the amount of active satellites. Red color of satellite icon means that current user’s location is not defined, yellow satellite color stands for obtaining data on the coordinates through A-GPS, and icon becomes green, when there are no less than 4 active satellites.
    New search of the “Nearest” POI.
    Before searching the nearest POI, user is offered to choose the place, according to the search will be done: near the needed address, along the route near finish point, or around the place pre-specified by cursor on the map.
    Map rotation with two fingers.
    If device display supports technology Multi-touch, rotation with the help of two fingers on the device display allows switching map orientation by cardinal points. For devices without Multi-touch support map rotation is available with smooth finger movement at the scale.
    Speeding warnings.
    Apart from Speedcam warnings, Navitel can warn user about speeding at the current section of the road. To adjust the warnings settings (visual or voice, the scale of speeding’s) go to Settings menu, to “Warnings” section.
    Option “Rotation during movement”.
    Function of map rotation during movement is changed. Map rotation is done now according to user’s movement, in spite of direction of the route.
    Route planning is improved.
    Updated route planning, taking into account traffic jams information, allows avoiding unnecessary detours while routing. The mistake with route in a straight line during automatic re-routing is corrected. Changes were also made to the “short” routing. Option of routing, taking into account U-turns, was adapted.
    Visual effects.
    Displaying of 3D-models on the map were improved, at scale 2000km background color was changed to black (Space). The maximum amount weather forecasts at the map is reduced to 5 objects. Map rendering is improved.
    Changes were made to the function of automatic maps updates verification.
    Traffic jams information uploaded earlier will be available when restarting the program.
    Support of smartphones and tablets with high display resolution was improved
    Possible voice stutterings were corrected at some Android-devices.
    Stability and working speed of Navitel Navigator were improved.
    Attention, users: display priority lanes at maneuver function will work only at official Navitel maps release Q4 2011.
  2. The Following 3 Users Say Thank You to trosten For This Useful Post:
    Mar 2012
    Re: Navitel Navigator v5.1.0.47 For WinCE
    Thank´s for the files!
    I put it on my wince 6, and when i click on navitel.exe, got a navitel error "Instruction at (0xf000fe74) reads from invalid adress (0xf000fe74). Handler: (0x00342230). (Build 5.0.4.0)."
    Any ideas?
    Jan 2012
    Tehran-Iran
    30
    as you wrote in another forum i know you resolved the problem.
    May 2012
    I have a locked map (nm2) of Sri Lanka. It indexes for Navitel Android version, but does not index for WinCE. Do you have any idea how to fix this?
    barbosa59 is offline Private
    Feb 2012
    15
    Quote Originally Posted by schrank01 View Post
    Any ideas?
    Same here.
    enetilah is offline Private
    Apr 2012
    Hi, thanks! which is map folder? I mean, where do I have to paste the map file? thanks again
    Jan 2012
    Tehran-Iran
    30
    after first run it makes a folder "Navitel content" and in that folder ther is a map folder .you must copy your map files in Map Folder.
    regards
    trosten
    Apr 2012
    Thanks trosten! done... but it doen't work on my WinCe 6.o device. Any Typ?
  10. #9
    Jan 2012
    Tehran-Iran
    30
    Dear enetilah it seems some WinCE6 devices have problem with this version(it is OK in Wince6 emulator)so please copy the files in root of your SD Card and try to run "start params.exe" or "start taskmgr.exe" instead of "navitel.exe". if it is unsuccessful so try this version of navitel for wince6
    Nav5.0.0.693WinCE6.0Rus.rar download for free on file share letitbit.net
    it is cracked and no need activation.
    Regards
    Trosten
  11. The Following User Says Thank You to trosten For This Useful Post:
  12. #10
    Apr 2012
    Thanks! I'll try
