Navitel 5.1.0.48 and COM port patch tool (WinCE)
Tested and working on chinese PNA, WinCE 6.0, 128 megs RAM, SDMMC, COM 1
Patch for COM ports, and several navitel executables alternate modes are included in the archive
No map included
Eventhough the patch's menu is in Russian, the menu itself is very simple and pretty self explanatory, should be no trouble for one to use it to patch the executable according to one's gps com port
The default is COM port 1, so no need to use the patch for PNAs with COM port 1
All credits goes to the original Russian scene uploader ^___^
Navitel 5.1.0.48: :link:
Pass
NOTE : The navitel's system menu WILL always display "COM1", even after being patched into another port, but it will work nonethelessCode:viriacaine1279
Links updated
Enjoy![]()
Does this work or run on WINCE 5.0
eLink Down. Please revise
Your link down, can you PM me please ? can i use for com 2 ? thanks
link down, please upload in other link
thanks
com port patch doesn't work, exe file is still com1 even patched.
Link updated, sorry for such a long time response, I'm quite busy in the real world![]()
Then it is the wrong com port that U patched
Anyway, I uploaded a newer version of navitel (5.1.0.97), with all prepatched exes for com 0-9, but when I posted it, the msg "waiting for moderation" popped up
I also uploaded it on another forum, feel free to try it
Code:http://www.**************/showthread.php?9855-Navitel-Navigator-5.1.0.97-for-WinCE-5.0-6.0-All-COM-PORTSCode:http://www.warez-bb.org/viewtopic.php?t=15421184
Thanks. It works.
I have a locked map (nm2) of Sri Lanka. It indexes for Navitel Android version, but does not index for WinCE. Do you have any idea how to fix this?
