Thread: Navitel Navigator v5.5.0.182 Cracked (Android OS)
    trosten is offline Sergeant
    Jan 2012
    Tehran-Iran
    30
    This is latest version of Navitel Navigator v5.5.0.182 Cracked (Android OS)
    i found this in internet just a few minutes ago and i don't know who cracked it but i tested and it works fine with new design.
    No map included
    Download Navitel Navigator v5.5.0.182 Cracked, Full (Android OS):
    Navitel_full_5.5.0.182_Cracked.rar download for free on file share letitbit.net
    + Mirror:
    Бесплатный файлообменник TurboBit.net — обмен файлами до 100 Гб, бесплатный хостинг файлов
    Download Navitel Navigator v5.5.0.182 Cracked, RePack (Android OS):
    Navitel_full_5.5.0.182_RePack.rar download for free on file share letitbit.net
    + Mirror:
    What's new in Navitel 5.5 for Android:
    - Completely revised and updated interface design software!
    - My Navitel - a new section in the menu where you can shop, download free software updates and maps, view data on your license.
    - New widget in the Route menu - will appreciate the simplicity and ease of construction and editing routes of any complexity, add to the route waypoints as you want.
    - Completely redesigned menu item "Settings" - make it easier to control the display of elements on the screen, choose the voice packets, modify the skin files, install sensors, edit profiles and much more.
    In addition:
    - Improved visual appearance of the maps Navitel.
    - Added the ability to pre-listen to the voice packets.
    - Implemented a new search on top of words (only works on maps release Q1 2012).
    - The rotation function maps for the convenience of users made less sensitive to the touch screen.
    - Added option "Avoid ferry" for routing (only works on maps release Q1 2012).
    - Fixed errors in the search for intersections.
    Also included are numerous minor bug fixes that improve stability and reliability of the program.
    Regards
    Trosten
  2. The Following 6 Users Say Thank You to trosten For This Useful Post:
    Re: Navitel Navigator v5.5.0.182 Cracked (Android OS)
    And some maps?? PLS
