1Likes
Post By trosten
Navitel Navigator v5.5.1.0 For WinCE
Hi Dear friends. this is Latest version of Navitel Navigator v5.5.1.0 For WinCE.
Maybe some crashes in some devices.
it is cracked and NO Map included
Credit goes to (iranian Cracker) Carbuncle
P.S: it is COM1 and Baud Rate 57600. if your device uses different COMPort and Baud Rate you can use "change Navitel COMPort" folder for adjusting the suitable Navitel.exe for your Device.
Download:
NaviTel Navigator 5.5.1.0 WinCE - hamta Corp. Edition by Carbunclel.rar
Mirror:
https://hotfile.com/dl/163688185/19a...nclel.rar.html
Another Mirror:
Download Navi Tel Navigator WinCE hamta Corp Edition Carbunclel rar
What’s new in Navitel Navigator 5.5.1.0:
Route line with traffic indication! Now it’s even more easy to get traffic information , while driving.
New design of display pages “Satellites” and exchanging SMS-messages is implemented.
Font in program menu settings and information dashboard was enlarged.
Size of switches was enlarged in menu “Settings”.
Improved routing algorithm allows to avoid “loops”, while route planning, taking into account traffic data.
Map search at menu “Search” was moved to the end of the list.
For Android devices option of sound channel selection for audio playback was added.
Bug with incorrect warnings about speeding was fixed.
Bug with route planning at the mode “The fastest” was fixed.
Stability and performance of Navitel Navigator were increased.
Regards
Trosten
The Following 4 Users Say Thank You to trosten For This Useful Post:
Re: Navitel Navigator v5.5.1.0 For WinCE
hi
attention!! this software Navitel Navigator v5.5.1.0 for Windows Mobile
9 There are many virus trojan
I did scan bitdefender
The Following User Says Thank You to Airion For This Useful Post:
The content of the "change Navitel speed" folder maybe shown as Virus in some antivirus software.if your device works with COM1 and 57600 Baud there is no need to patch the Navitel.exe file.if your device uses different COMPort don't worry about it. disable your antivirus auto protect for a few seconds and then patch the Navitel.exe ....after patching you can enable auto protect of your antivirus software.
Regards
Trosten
The Following User Says Thank You to trosten For This Useful Post:
6th August 2012, 00:01
#5
Dear Trosten,
It's not working in my chinese headunit with WIN CE 5.0.
It seem for Win CE 6.0 or Win Mobile.
