Hello all,
Good to know we are back again. I really missed all of you guys!
I have a case here with Navitel. I can run Navitel in wince 5.0 but somehow the same version does not work for wince 6. I got error message something like "Map files and executable modules are missing....pls check your flash card....".
All the configuration files are in the same structure with the other device using wince 5.0.
Do you guys has the solution? Have check the other forum but problem remains.
thanks!
same with my problem too. Anyone solve ? share please .. Thank you.
1. To unpack archive contents on a SD-card.
2. To put contents univce5 (for WinCE5) or univce6 (for WinCE 6) in a folder with Navitel.
3. To start NavStart.exe.
4. In the appeared window to press APPRX.
5. To switch off the navigator and to reboot.
6. To start Navitel.exe
Assemblages are rigidly adhered to name SDMMC, but it is possible to create simply folder SDMMC with the same name and all will work (in a case if the SD-card is called on another).
Indispensable condition - the navigator should keep register changes. At whom the register does not remain - to that has not carried.
can anybody help me out with unlocking navitel maps ?
hmmmmmm not help ?![]()
Read here for some details
Navitel Southeast Asia Maps
Thank you but i think sri lankan map is not in that link what u have given to me ? can anybody upload the map![]()
No idea whether Sri Lankan map exist or not.
Maybe you google to find it.
Sala use Navitel and they have Sri Lanka Maps. but that maps are locked. Can you anybody unlock this maps? I will post lakdasun post regarding that.
Guys,
I have uploaded a clone from a Sala ProSat Device which includes their highly updated SriLankan Maps along with the Navitel Software, Anyone who can make this work (Requires a Keygen + or a Crack to the Map files) Please Post it here, or anyone with coding experience please try to make this work.
Sala ProSat uses Navitel Navigation software, Which runs on almost all Windows CE devices, Chinese GPS units, Symbian, iOS and Android Platforms.
Making this work may lead to the point of getting read of slow, laggy and outdated Garmin Mobile XT.
LINK
Navitel Navigation.7z
