Find the MFM map in Garmin/ MSM& MFM map thread.
Conversion to nm2 is lots of work.
I don't stay in Sabah. So never do it.
Perhaps someday I do it.
Till then I post it.
MFM-Garmin 110926
Free Malaysia, Singapore, Brunei & Thailand Garmin GPS Map
Hi everyone I need help;
Plz correct me If my procedure is wrong.
-first I'd downloaded this file came from this thread http://letitbit.net/download/16600.1...vated.rar.html
-second I downloaded Nsea.rar
- 3rd I install the Navitel-3.5.0.1400_activated.rar to my samsung galaxy fit (I extracted it ob-course)
-4th I create an directory to the navitel forder "sdcard/NavitelContent/413v326/Philippines/" under 413v326 I created another folder name "Philippines" folder
-5th under sdcard/NavitelContent/413v326/Philippines/ folder I copy the Philippines.nm2 files. something like this sdcard/NavitelContent/413v326/Philippines/Philippines.nm2.
then I' open the navitel application the screen show
Navitel
(black background)
then after a few seconds the application automatically close.
Plz Help
thanks advance
Map in 413v326 folder direct.
No sub folder philippines.
Atlas don't detect sub folders
Thanks for reply, unfortunately I got the same result, may be I change the Navitel-3.5.0.1400_activated.rar activated version, by the way I using android gingerbread 2.3.4
Check this thread
Navitel for Android
i looking for navitel wince 6 support southeast asia maps, i try many version but it dont work! my device lokatoo a1000i com7 baud 4800
anybody have this software..
you can find all iran maps in this link:
نقشه های GPS سازگار با نرم افزار NaviTel - پاکت پی سی
