Thread: Help!! Navman iCN530
    Please help me , i have been trying to instal mio pocket on my device , but the device can't find any SD card. What to do?
    NRT's Avatar
    NRT
    NRT is offline Command Sergeant Major
    206
    Re: Help!! Navman iCN530
    Quote Originally Posted by sds243 View Post
    Perhaps the 530 does not support sdhc try using a card that is just SD
    Ok , will try that. Ill let you know if it works. Thanks for the tip .
    dra
    dra is offline Sergeant
    54
    Hi, i have an ICN530 running with a 2GB basic SD card - I think it will only read this size and no bigger
  1. 26th July 2011, 12:15
