Results 1 to 10 of 12
Thread: Ndrive for Symbian
    dvbfucker is offline Corporal
    18
    Ndrive for Symbian
    If anybody know, is there any other way to install ndrive 10 on symbian without waiting for certificate on OPDAÊÖ»ú×å - Ãâ·ÑÊÖ»úÈí¼þÏÂÔØ|Ãâ·ÑÊÖ»úÓÎÏ·ÏÂÔØ|Ö¤ÊéÏÂÔØ
    It was fast before, but now you must to wait for about a week to get certificate.
  2. The Following User Says Thank You to dvbfucker For This Useful Post:
    Re: Ndrive for Symbian
    Download your certs from opda download freesigner then put them all on your phone & you can sign the files on your phone rather than waiting
    Freesigner
    18
    Wait, what? This file "FreeSigner_v101" (that You provide) install on my phone and with this application I can make any unsigned application signed? Is that correct? Did You try? If FreeSigner_v101 works it will be awesome.
    BigMac's Avatar
    BigMac is offline Sergeant First Class
    103
    125
    Quote Originally Posted by dvbfucker View Post
    FreeSigner Tutorial
    FreeSigner that allows you to directly sign symbian 3rd edition software, applications and games on your mobile device without transferring the files to your computer.
    What's new:
    1- support removing signature
    2- support PKCS#8 private keys
    3- support batch works
    4- support customing the signature cert and self-sign cert
    5- support customing the output directory
    FreeSigner supports following phones:
    3250, 5700, 6110N, 6120C, 6121C, 6220C, 6290, E50, E51, E60, E61(i), E62, E65, E70, E71, N73, N75, N76, N77, N80, N81, N82, N91, N93(i), N95, N78, N79, N85, N96
    Lets Begin.
    Preperation:
    put your UNSIGNED app to a folder on your mobile/memorycard you will remember.
    This is the location i chose: Computer\Nokia E71\Memory card\Others
    Install and start FreeSigner.
    Click Add Task.
    Find the location of your UNSIGNED app, highlight it and click Options > Add > SignSis
    In Your file explorer, go to where the UNSIGNED file was located, and you will notice a new SIGNED copy. Use that and it will install.
    Good luck
    18
    I have try on couple symbian phones and just have no luck with freesigner, so, freesigner is not a solution because simply does not work. Currently I have no idea how to install unsigned ndrive on symbian because websites like shoujizu.net and s60certkey.com seems like they not deliver more new certificates for free.
    Yes I use this myself, so it does work, but you have to get your certs from one of the sites like opda.
    Now there is a way to do it without any certs, just have a look here
    cholak is offline Private
    Dec 2010
    Try this one:Symbian Hack! No Need of PC! | Symbian Lagenda
    No need for cert.key.
    filipsrbin is offline Private
    Mar 2012
  10. #9
    Mar 2012
  11. The Following User Says Thank You to filipsrbin For This Useful Post:
  12. #10
    18
    Quote Originally Posted by filipsrbin View Post
    Is this unsigned installation of what?
