Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Like Tree4Likes
Thread: NDrive v10.1.15 WinCE4.2/5/6
  1. #11
    boxtraenco is offline Corporal
    18
    Re: NDrive v10.1.15 WinCE4.2/5/6
    Great... This maps work alsoo on Sony Ericsson X-10 ( Android 1.6).
    Boxtra
  2. #12
    Great post thank you , btw i only have the time problem too
  3. #13
    Great Britain Maps 404 error - Not Found
    EliTom
  4. #14
    Galati
    i've install in NavMan icn 530 and works but how get maps ? Thanks .
  5. #15
    Hi
    I've installed it in a Medion E4240 (G800 compatible) but I'm not able to see the PT Map, only the World Map. And everytime I try to navigate or find an adress, for exemple, it takes me to the "About Map". The map is registered (I bought the program from Ndrive).
    Any help will be very usefull!
  6. #16
    Obrigado companheiro
  7. #17
    3,132
    223
    Ensure that your software is working properly.
    For maps problem -
    Create a sub directory for each country
    Maps/country/ozimap file.
    The world map in the root of the map directory
    maps/world.file
    Try this out.
    For configuration problems -
    edit the ndrive configuration settings to match your device setup
  8. #18
    Xplorer is offline Private
    Hi guys,
    I got problem when running it under double din car dvd gps windows ce 6. When it loads at the first time, stuck at "Init. Security..." stage. I hv wait for long time but it just do nothing. What went wrong? Appreciate your help. Thanks.
  9. #19
    LFGringo is offline Private
    Thanks Mate, working in my Acer E300...
  10. #20
    For maps problem -
    maps/world.file
    Try this out.
    Hi Airion,
    Im still having problem, Ndrive still cannot find the map. I hv tried to moved the map file to \country\xxx.map file but it still cannot be found.
    is there any convention on country wording?
