Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
Like Tree4Likes
Thread: NDrive v10.1.15 WinCE4.2/5/6
  1. #21
    Re: NDrive v10.1.15 WinCE4.2/5/6
    will this work on a touch pro 2 ...tmobile gsm wvga
  2. #22
    sas_sas is offline Private
    Hi bro,
    My trouble is the same with you.
    NDrive stops when comes to "init securiyt" stage in My winCe 6.0 unit too.
    How did you overcome the stopping issue during first run/install ?
    What soft?
    What Medicine ?
    What version of Map?
    Ths in advance..
    Quote Originally Posted by Xplorer View Post
    Hi guys,
    I got problem when running it under double din car dvd gps windows ce 6. When it loads at the first time, stuck at "Init. Security..." stage. I hv wait for long time but it just do nothing. What went wrong? Appreciate your help. Thanks.
  3. #23
    3,132
    223
    Those who have problems with starting Ndrive
    Check your Ndrive configuration settings.
    Use ultraedit or any file editor
    Ensure that your device info is found inside this file
    if the details like com and baud are not correct - edit them to match your device.
    If your device exact details does not appear inside.
    The choose your device brand and edit the model info
    replaced your original exe file with the one here.
    this works fully for WinCe ver 5.00
    For other Ce version - you may try and see.
    getais likes this.
  4. #24
    I replaced the ndrive.exe for unlock the map but I got the message "Inncompatible image file!" . May I know how to solve this problrms?
  5. #25
    Hello
    first of al ..hello , iam new her and like to say hello to everyone
    the problem i have is install the ndrive v10 to my HTC HD2 win mobile 6.5 pro T8585
    just by the begining already ,,failed
    right from the beginning
    and i dont know why ,,,hope you know why and can help my
    mass,, is, it is injure ,from a 3th person and i can damage the mobile ,,,,
    many thanks in adv
    Stefan
  6. #26
    Need help can't get ndrive to work on MIO C320. ndrive 9 work fine but when try to run ndrive 10 it say can't find ndrive.exe or one of the components
  7. #27
    Dec 2010
    Original NDrive.exe can be launched but not with unlocked one on WinCE5 on my device(magellan roadmate) 'NDrive' is not valid Windows CE application any fix?
  8. #28
    Feb 2011
    Does this version works with ndrive g280 winCE 5.0
  9. #29
    Quote Originally Posted by Muflone View Post
    I don't think so...... this nDrive 10 is too big in my screen (big streets, big POI, etc...).
    When i used nDrive 9.2.44 it was smaller (more view in neighbors....).
    I'll try to copy nDrive.ini settings from 9.2.44 to this new nDrive 10.
    Good, I have a Maestro Megallan 4040EU with WINCE Core 5 and I can not put 10 or 11 ndrive working. I have already put several versions of wince 5 but so far without results. Version 9.2.39 works but the latest thing.
    Anyone have ideas?
    Thanks.
  10. #30
    Aug 2011
    Hi this sw will work in my G50? thanks in advance
    Saudações leoninas.
    Sporting Sempre!!
