Thread: speed camera warnings for ndrive UK
    Hi can you tell me what file format are the speed camera warnings in ndrive 10
    and were are they installed ?
    XisiX's Avatar
    XisiX is offline Corporal
    28
    Re: speed camera warnings for ndrive UK
    NDrive expects some extra information in the kml file.
    But here is one method:
    - Find speedcameras for your country in the internet in TomTom ov2 format.
    - Download and extract this NDrive speedcams importer from ervius (Thx to him!)
    - Put the ov2 file into the pdi folder of the program
    - Start the "Ndrive-speedcams-importer.exe"
    - Select "Import .ov2" at the bottom. On the right side you should see your ov2 file now
    - Select your ov2 file and hit the left arrow next to the "Fixed" field
    - Now hit the "Create Database" button
    - In the cams folder you will find the kml file now
    - Copy the kml file to NDrive/speedcams and import it via the menu.
    [Thx goes to druelie]
