Results 1 to 10 of 20
Like Tree3Likes
Thread: NDrive 10.2.10 for WinCe 5
    3,132
    223
    NDrive 10.2.10 for WinCe 5.0
    No maps included.
    Link below : -
    QOOY - Pick your file host - Download - Driver_Test.rar
    navigalo, grknktl and rotacao like this.
  2. The Following 24 Users Say Thank You to Airion For This Useful Post:
    Re: NDrive 10.2.10 for WinCe 5.0 & 6.0
    I've downloaded succesfully, but this software does not work in my PND/PNA (chinese).
    This software stuck and I could not see welcome screen.
    I've delete old version and copied this new version on my SDCARD, but nothing happened.
    WinCE:6.0
    PND: Chinese PNA 5.0"
    Any suggestion?
    Feb 2011
    It doesn't work at all. My PNA became frozen when I tried to start this version. (PNA: ARM Atlas V, 128Mb, 800x480)
    3,132
    223
    Check Ndrive configuration settings.
    Ensure your device type or model is inside.
    If not added it in.
    For non generic device - enter your processor model, com and baud rate
    With previous installation - transfer the details of configuration settings over.
    That should work.
  6. The Following User Says Thank You to Airion For This Useful Post:
  7. #5
    dont work freeze
  8. #6
    mikyhouse55 is offline Staff Sergeant
    95
    no work WinCE 6.0..
  9. #7
    3,132
    223
    Delete main directory navigation ID file.
    Data directory - delete appdata
    Check Ndrive Configuration settings - ensure your device name is inside
    Or
    Use your previous working Ndrive CS file.
  10. #8
    carl2222 is offline Lance Corporal
    Apr 2011
    I would like to know if anybody is having an issue with the recent locations feature. It doesn't seem to populate at all. I add as many routes as possible, successfully navigate to the destination but the recent list remains blank. Is this a known bug in this version? Is there a way to fix it?
  11. #9
    3,132
    223
    Quote Originally Posted by Vilen77 View Post
    Version is for 480x272 resolution.
    800x480 use v10.1.15
  12. #10
    nuno_nunes is offline Lance Corporal
    Is a software is work in GPS PNA Ndrive G400, yes our no, Thanks
