1Likes
Post By ar_156
3rd August 2011, 08:43
#1
magellan 2036
I have Magellan RoadMate 2036 and I tried to unlock.Becouse mgnShell auto start before softbuton i tried to kill that proces.Now i have "mgnShell' corupted PC don*t see my navigaor!!! Does anyone have a solution
3rd August 2011, 09:57
#2
Re: magellan 2036
IMG_0344.jpgDOes have any way to have back usb conection any solution or sugestion will help
3rd August 2011, 11:07
#3
Re: magellan 2036
I tried
(1) Download softbutton.exe to your computer(pc).
(2) Turn on the PNA and connect to pc via usb cable.
(3) Double click my computer icon,
Double click TFAT,
Click APP folder, Change name Navigator.exe to Navigator123.exe
Method: left click icon named Navigator, right click, select rename,
type in Navigator123, press return,
(4) Copy softbutton.exe to App folder,
(5) In App folder, change name softbutton.exe to Navigator.exe, remember
no need to type in .exe after Navigator,
(6) In pc screen right bottom corner, click the usb device icon to safely
remove the PNA device,disconnect the usb cable ,
(7) Connect your SD card reader to pc via usb, in SD card, in iGO8 folder,
double click sys.txt file, add in the following line and then click save,
Magellan 2036 dont have a card slot so I have put iGo on HDD.But when I start device Alweas mgnShell start first.Then i must kill that proces then run iGo.And then i saw a difrent way to start iGO automactly.Then i rename a mgnShell into mgnShelll and folder iGO i have rename into a mgnShell,also iGO.exe renamed inmgnShell.exe.When i start device i get a sreen on a picture I have attach.After that i read the mgnShell control a USB.Now Im stock on this.I tried to update device via Megallan Manager but soft.cant see device
26th February 2012, 00:06
#4
Re: magellan 2036
I have a RM 2036 too, I'd like to install iGo8 on it, can someone link me the files? Thank you!
26th February 2012, 13:26
#5
Re: magellan 2036
Help please.
After several days, searching and testing, all the links are down so I seek them one by one but still no joy.
I've done these on my Magellan Roadmate 2036:
test 1. replace Navigator.exe with SoftButton.exe version alfa1, alfa2, alfa3 after reboot I see the button but doesn't response, then nothing but the Magellan Radar
test 2. setup the .ini adding start with IGO8.exe but got cannot start application error, I press OK button and then nothing but the Magellan Radar
test 3. copied the iGO8 files into APP and rename iGO8.exe to Navigator.exe and edit sys.txt to address iGO8 folder into \APP\ got nothing but the Magellan Radar
Re: magellan 2036
Hello.
I have a Magellan Roadmate 2036 too.. I want to unlock it but i can't find a tutorial for this... I want to install igo in my GPS. Can you send me the unlock and igo "howto" ??
29th November 2012, 17:38
#7
Re: magellan 2036
I have magellan Roadmate 2036 I try every thing Mio Pocket . softbuton and nothing works ..can some body help me please
29th November 2012, 17:49
#8
Re: magellan 2036
Di you find the way to unlock it ???? I need help
29th November 2012, 18:00
#9
Re: magellan 2036
XXSHARK Make a backup of the internal memory,upload it to a sharing site and post link here.I will try to help you
