8th February 2012, 19:52
#21
Re: Cant load anything from SDMMC
windows CE desktop shows only for a sec. then goes in the background... and when i press navigation button nothing, i think it cant find sd card... maybe if it could be loaded from gps button...
9th February 2012, 00:49
#22
Did you try using shell.ini to point to \Windows\explorer.exe ?
9th February 2012, 04:27
#23
Tried that to
9th February 2012, 06:01
#24
Yeah, like I mentioned in posting #6, sdcard will be disabled once windows starts up ( due to corrupted registry ).
The only time sdcard is active now, is at start of cold boot, to read firmware update.
Since there is no firmware in sdcard, windows starts up and disable the sdcard reader and usb (corrupted registry).
9th February 2012, 07:23
#25
Is any way to solve this?
Regards
9th February 2012, 07:33
#26
The Following User Says Thank You to mitzy For This Useful Post:
9th February 2012, 07:34
#27
I'm still looking up the Russian and Chinese sites for the firmware for your device.
The Following User Says Thank You to hashima For This Useful Post:
9th February 2012, 07:47
#28
I think loader.exe is disabled in registry that's why it doesnt load sdmmc
10th February 2012, 07:10
#29
I klicked on navigation button but nothing happens
10th February 2012, 07:11
#30
Did you find firmware maybe?
Regards from Slovenia
