Thread: unlock GPS Travel Liberty 6
    denis72 is offline Private
    I'd unlocked the gps "liberty travel 6" to access to wince 5
    Do you know of a solution?
    Denis
    gyany is offline Lieutenant
    Mar 2012
    A, A
    368
    Re: unlock GPS Travel Liberty 6
    denis72 Make a backup of the flash (internal memory), upload it to a sharing site and a post here Linck.I will try to help you...
    I saw on a French site by using the explorer.exe file from Wince 5 I can unlock the GPS.
    Can you send me the file because it is absent in the GPS?
    Thank you.
    I managed to unlock the GPS.
    We must put the explorer.exe file to the root of ResidentFlash. This file is located in the software Miopocket.
    Then edit the file schema.ini for the parameter button activates the explorer.exe file.
    Excuse me for English because it is automatic translation from Google.
    Goodbye.
    PADA II's Avatar
    PADA II is offline Corporal
    Jul 2012
    21
    The "explorer.exe" is not necessary, is already in WindowsCE.
    *Open the schema.ini file.
    *Modify the command line in red:
    [MP3Btn]
    Rectangle=29,131,64,64
    Caption=TxtMP3
    CaptionRectangle=14,196,100,20
    Font=FontSettings
    Color=255,255,255
    Action=\Windows\explorer.exe
    *Reset and start the GPS.
    *Press the MP3 button and must appear the WindowsCE.
    My messages are translated with bing
